Old 09-01-2012, 01:42 AM   #1
PrecisionX
My Ride: 2002 330CI
Cooling system (CHECK!)
This is Harriet and she has 55,880 miles on her and is just back from the shop. She had the following done:
Water pump with metal impeller
Fan switch
Thermostat and thermostat housing
Sealing gaskets
Expansion tank & cap
1 Gallon Coolant
Upper & lower radiator hoses
And temp sensor
The belts are in good shape and the mechanic said after looking over the car they found no surprises and that it was in very good shape.
PrecisionX is offline   Reply With Quote
Old 09-01-2012, 02:31 AM   #2
MJLavelle
My Ride: 2001 BMW 330ci
Wrong forum. You want "Model_T_Fanatics.com" where people can talk about cars named "Harriet", "Bessie" and "Buttercup" with a straight face.
However, we are glad you got the cooling system replaced.
Let us know when you get that pimpin Chrome Hand Crank, and remove a leaf spring for an 8 inch drop.
You don't need to tell me, I know I am being a d!ck tonight. I'll save you the post.
Old 09-01-2012, 02:39 AM   #3
MercForHire
Sh1tty Advisor
My Ride: 323Ci 5 Speed Black
I am sure the mechanic is saving the old water pump, hoses, and expansion tank for another e46 because at those miles, these are barely broke in.
What a hand-out for the mechanic
Oops! My Water Pump Broke Again .................... Coolant in a Bottle
Old 09-01-2012, 05:47 AM   #4
dmax
Stay stock my friends!
dmax's Avatar
My Ride: '99 328i 1.04646 mu
That one gallon of coolant...I hope they added water (distilled) to make a 50/50 mix....and I hope the thermostat with housing was an OE wahler plastic housing...as the aluminum ones seem to work only days at most!
BTW, next time, the composite blade WP is fine. The panic over plastic wp blades falling apart is over...that was quite a while ago and since then bmw has made a better composite. No worries.
dmax is online now   Reply With Quote
Old 09-01-2012, 08:35 AM   #5
DJ Syxx
My Ride: BMW M3
You realise they don't just fail depending on mileage, its also to do with age.
AC Schnitzer Styled M3
DJ Syxx is offline   Reply With Quote
Old 09-01-2012, 10:25 AM   #6
BMWespresso
My Ride: 2005 325CI
Great girl, very low miles i'm at 85K ready to do cooling redo when weather cools down here
BMWespresso is offline   Reply With Quote
Old 09-01-2012, 11:14 AM   #7
EverydayGetaway
My Ride: 2003 330i ZHP
Wrong.
EverydayGetaway is offline   Reply With Quote
Old 09-01-2012, 11:18 AM   #8
tock172
100% star stuff
tock172's Avatar
My Ride: 2004 330i
Cool! Now you've got many more miles of peace of mind! Your car makes me want a steel grey pre-facelift coupe. So clean.
Bilstein/Eibach B12 Pro-Plus Suspension & Sway Bars | DICE Mediabridge | Valentine One
Old 09-01-2012, 01:33 PM   #9
PrecisionX
My Ride: 2002 330CI
Well I want your suspension, how's it feel compared to stock? My
Suspension is doin fine but I want bilsteins and hr springs next. This car sticks well stock when pushed but I can only imagine it with that set
Up.
Old 09-01-2012, 02:07 PM   #10
john311tran
My Ride: awd + 5 doors
haha.. seriously right? must be nice to have money to fix perfectly working things. i can see prevent maint at like 100k. but 55k? shiat. that's like a new car.
john
john311tran is offline   Reply With Quote
Old 09-01-2012, 03:04 PM   #11
tock172
100% star stuff
tock172's Avatar
My Ride: 2004 330i
john
Come on now. His car was manufactured in 2002. I think he made a good investment having the cooling system replaced.
Up.
It feels incredible. Definitely something I recommend when your stock components wear out.
Old 09-01-2012, 05:06 PM   #12
EverydayGetaway
john
WRONG.
There is more to preventive maintenance than mileage, in fact there are plenty of people out there that would argue age is a bigger factor than mileage.
Old 09-01-2012, 06:32 PM   #13
PrecisionX
My Ride: 2002 330CI
I dare someone to roll the dice with their cooling system because of mileage
Old 09-01-2012, 08:47 PM   #14
katu
My Ride: '04 330ci ZHP
OP is at 56k miles, my ET failed at 65k miles, all you people claiming he made the wrong decision are....
As others have mentioned the car is 10 years old, the failing of a cooling system has a lot to do with heat cycles, not just mileage.
katu is offline   Reply With Quote
Old 09-01-2012, 09:13 PM   #15
MercForHire
Sh1tty Advisor
If you habitually overfill your coolant you can pretty much blow an expansion tank every year.
Old 09-01-2012, 09:16 PM   #16
EverydayGetaway
When did anyone ever say they overfilled anything? I'm sorry, you're just wrong, plain and simple.
Sent from my DROIDX using Bimmer App
Old 09-01-2012, 09:51 PM   #17
john311tran
Originally Posted by EverydayGetaway View Post
WRONG.
my car is 10 in 4 months. original expansion tank and working perfectly fine. i'm going to change it next spring as preventative maintenance. it should be at about 110-115k miles by then. change at 56k. that's a silly waste of money if you ask me.
but hey, if you got an extra 400-600 laying around then by all means, go for it. it's not going to hurt you.
john
Old 09-02-2012, 12:12 AM   #18
EverydayGetaway
^I'll be the first to lol when your "My EP tank busted" thread pops up.
Old 09-02-2012, 12:14 AM   #19
MercForHire
Sh1tty Advisor
The above guy is a strong case of a ZHP-Nazi who is hypnotized into thinking his car equals a Porsche 911.
Ignore him
Old 09-02-2012, 12:16 AM   #20
EverydayGetaway
The above guy is a strong case of a ZHP-Nazi whose is hypnotized into thinking his car equals Porsche 911.
Ignore him
You're hilarious, really. I've had my "ZHP" for less than a year and bought it because I wanted the best E46 I could buy with 4 doors. My opinions would be the same if I were driving a 530i (as I was originally looking for) or a plain jane 330i. Good maintenance doesn't stick to ZHP owners alone...
