Sponsored by BimmerWorld
Old 09-02-2012, 01:57 AM   #1
always-there
My Ride: 2002 BMW 330I
E46 330i front struts
So for a while now I've known my front struts are completely blown. Whenever I go through speed bumps, I can hear metal on metal contact as if it's really loose. I've replaced shocks before, but this will be my first BMW strut job. I'm sure it's the same concept, I just wanted insight on what dampers to buy if I want sharp handling, just not too stiff. And do I really need new shock mounts aside from the strut mounts I know I need ?
Old 09-02-2012, 04:16 AM   #2
swordsman11868
My Ride: 2003 325i
Metal on metal? Sounds like u need more than just the struts.
Could be the end links but you won't know until you get under there and look.
-d
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 09-02-2012, 08:58 AM   #3
BimmersGarage
My Ride: E46 330i
How many miles on your ride?
That's some severe wear/damage. Lower ball joints in LCAs and FCABs could also be failed.
BimmersGarage is offline   Reply With Quote
Old 09-02-2012, 01:25 PM   #4
always-there
It has 121k.
Old 09-02-2012, 05:17 PM   #5
yetieater
My Ride: '03 330i
The dealership would replace your strut mounts at the same time as the struts if you took your car there, so I'd do them as well. Bilstein gets great reviews.
bulletproof one piece at a time
full listing of BMW Performance parts for the E46
yetieater is offline   Reply With Quote
Old 09-02-2012, 05:39 PM   #6
MercForHire
My Ride: M235i 6MT
Install a pair of these as well
http://www.turnermotorsport.com/p-32...ates-pair.aspx
Old 09-03-2012, 12:30 PM   #7
nike001
My Ride: Fergo
^ +1,000,000
cheap and will potentially save you a lot of money in the long run. There's no reason to not do this
2015 M235i 6MT
nike001 is offline   Reply With Quote
Old 09-03-2012, 01:06 PM   #8
smolck
My Ride: 2004 ZHP Sedan
Koni yellows. Adjustable and amazing. Done
Check out my BMW Blog
http://smolckbmw.blogspot.com/
Check my Youtube channel for DIY's and fun stuff
http://www.youtube.com/user/flipfinish?feature=mhee
smolck is offline   Reply With Quote
Old 09-03-2012, 01:14 PM   #9
Stinger9
My Ride: '04 330Ci
Stop driving immediately
Sound could be indication of drastic damage being done.
Inspect before you drive another mile.
Old 09-04-2012, 11:19 PM   #10
speedlaw
My Ride: 03 330i Sport
Replace with Bilsteins. While you are there, FCAB and sway bar bushings are a few bolts away-the problem is that once you fix one thing on an #E46, the forces will move to the next weakest link-and kill it. Replace end links too, for a fat $40. If you view it as the suspension being suspended by FCAB, Sway bar bushings, Shocks and mounts, you'll be way happier at your mileage to replace all rubber bits and forget about it all for another 80k.
I did Meyle Control Arms at 180k, and at 290k, the uprated ball joints are still good. Meyle is a great OE replacement part.
330i Sport, Xenon, Nav, Cloth Interior, NO Sunroof. Valentine One, Icom 7000 for Ham Radio, Scanner, and CB.
speedlaw is offline   Reply With Quote
Old 09-04-2012, 11:33 PM   #11
Stinger9
My Ride: '04 330Ci
Had to reach out to a fellow "NO sunroof" brother!
Check out my garage and you'll see it is a valuable trait for me. Special order.
Admire your cloth interior too! But happy with my leatherette.
Old 09-07-2012, 09:16 AM   #12
always-there
Yea, i really love this car, I don't want give up on it, so I'll replace everything. It's in fair condition, I dig the m3 wheels. I'm just waiting on the this coming paycheck : ( Ever since I bought it, I've been making a list of what needs to be replaced, and damn it's a needy car. But then again the previous owner seems to have just slacked off on maintenance.
Old 09-07-2012, 09:21 AM   #13
MercForHire
My Ride: M235i 6MT
That's what the next owner gonna say.
Driving until things blow then fix it
Old 09-07-2012, 09:29 AM   #14
always-there
Maintenance needed for the BMW- New struts, shock tower mounts, strut tower mount, alignment, oil change(buy wix), cabin air filter(replaced), window tint - not really a necessity, at least yet-, window regulator, fuel filter, air filter, and whenever I get the opportunity replace the abs sensors/rotors/and inspect brake pads(drilled/slotted)hmm..Take Bimmer to a professional detailer so they can take away the weird old cigar smoke the previous owner put in the car. Oh and today the car hesitated to start, so I'll need to replace the spark plugs..well basically a complete tune up, depending on how much I can afford at the time. Fix the C pillar in the rear passenger side, which isn't too bad. The center console has a couple of scratches so I'd like to get a brand new replacement. Brand new rain x wipers to replace current set which still work, I just want to get it done so I don't have to worry about it. Make sure a/c has enough freon. After this is all done, replace transmission fluid which includes replacing gasket, filter etc. And after this is all done I can safely enjoy my joy rides on the freeway, lol.
Old 09-07-2012, 09:55 AM   #15
always-there
When I bought the car, the struts were already blown.
Old 09-07-2012, 09:57 AM   #16
MercForHire
My Ride: M235i 6MT
Very nice. You just noticed.
Old 09-07-2012, 10:05 AM   #17
always-there
No I knew, I just fell in love with it. I knew it needed to be replaced, and with a credit score of 580ish, I knew I couldn't get a nice Bimmer for cheap. For now, this is the closest I could get aside from Carmax who wanted 6k down on a 07 328i with 60k miles, 456 per month at 18% interest, and that's just nuts. So here I am. The car is amazing, it just needs maintenance since the previous owner was an idiot. All in all, it's all good, just seeking insight on current BMW owners. We never stop learning.
Old 09-07-2012, 10:39 AM   #18
BimmersGarage
My Ride: E46 330i
It has 121k.
OP,
@ 121K+ miles...
I said you need to focus on a complete cooling system refresh/overhaul (priority), suspension next (INCLUDING your hub/bearings*), then everything else in that order.
And, check your DISA.
*I'm betting there's an annoying droning 'road' noise that gets worse at speeds.
Old 09-07-2012, 11:21 AM   #19
jdstrickland
My Ride: '94 325iC & '00 323i
-d
+1. Even a blown strut should not make metal on metal noises.
The job that the strut performs is essentially the same as that which a shock does. Springs support the weight of the car, shocks and struts control the bounce and rebound of the springs. It is very rare that a shock/strut will produce a metal on metal noise.
I would suggest that you do indeed need shocks and struts, but the noises are from bushings or the springs themselves. There are supposed to be rubber pads between the springs and the spring seats, and if the pads are gone then there is metal on metal. The struts have a top mount that is basically a bearing so the struts can pivot when the car is turning. These mounts can be a source of metal on metal as well.
Old 09-07-2012, 11:44 AM   #20
always-there
The disa's fine. The car sounds great, it's pretty quiet on the freeway, so I'm good there. When I turn it on the car sounds pretty strong. I'm not sure if the owner did any mods to the exhaust set up, but it sounds a lot better than a stock 330i muffler. I did notice the golf tee mod was done since the valve on the muffler's open at idle.
