#1 |
Help! Im Only Getting 150 Miles to a Full Tank of Gas
I just got my car back from being painted in the shop, and now I am burning through gas like crazy! I pulled codes with peake and the only code im getting is "coolant temperature plausibility". I changed my coolant temp sensor last week, erased it and its back. I have searched and I see this code looks like it is for thermostat. Could this be my problem? I have also noticed when i pull into my garage it smells like fuel. The smell is coming from the exhaust pipes, so Im guessing something is telling my car to run rich. Im positive it was not doing this before I dropped it off at the shop. If I could please get some help it would be greatly appreciated. Thank You
#2 |
Ride with the MAF out for 25 miles or so. Do the math and see if it helps.
#3 |
There a lot of complains about body shops smashing ecu/ground wires with fenders etc.
Sent from my SAMSUNG-SGH-I747 using Bimmer App |
#4 |
Stay stock my friends!
Thermostat. Drive on highway...you'll see your temp needle drop slightly to the left of center. With any luck, maybe they just unplugged the therm, but that will cause you to get horrible gas mileage and that's what I thought before I saw you had a therm code!
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
#5 |
As soon as you plug the MAF back in, the transmission should go back to normal. I've done it many times.
#6 |
So have i.....it diagnosed a lot for me. And your transmission doesnt go into limp mode.
#7 |
This is what I would do first. Part is pretty cheap, work isn't bad. Go ahead and replace the entire coolant system if it hasn't been done yet. You should know the drill by now.
For Sale: Auto Trans E-fan - http://forum.e46fanatics.com/showthr...3#post12840603 23.5mm Front Sway Bar - http://forum.e46fanatics.com/showthr...0#post13054250 18mm Rear Sway Bar - http://forum.e46fanatics.com/showthr...8#post13054258 |
#8 |
I'm with DMax, a cold engine = sh!tty gas mileage.
#9 |
Why not use the hidden OBC first to see if the coolant is getting up to temp. The needle may show center, but center is 75-105 Celsius. I agree with dmax however, cold engine means shitty mileage.
2003 Jeep Wrangler Rubicon 2000 BMW 323ci 1995 Saab 900 SE - JZW Stage 4 |
#10 |
I agree with me also...but I have to say also that mpgs have been discussed before many times...use advanced/title search for 'mpgs.'
The cribs of the collected mgp wisdom: air filter, fuel filter, plugs at 100K small intake leaks (though they usually throw a code...they often don't throw a light) ...and then all the other things we do to keep things tight...vcg, ccv, new o-rings and rubber wherever you happen to be (though, at 237K miles, all my vac hoses were intact...they just broke when pulling them off of their nipples). Therm and fuel filter together gave me 3 mpgs...about 1.5 better mpgs for each replacement. Also, rather than report your miles per tank, average mpgs at an average mph 'on' a tank is a much better gauge. I know I get 'around' 22 mpgs when I've done 'around' 250 miles at an average speed of 25 mph. I get 34.5 mpgs when going for a long run on the highway at 71-2 mph (it's downright dangerous in NJ/NY to maintain only the speed limit!) in fifth, in cruise. Anyway, just saying, so you have a reliable measure to compare your work against.
#11 |
#12 |
#13 |
#14 | |
http://www.kneb.net/bmw/E46/E46%20Trouble%20codes.pdf |
#15 | |
OP check the thermostat like said above, either in the Hidden codes or check the connection in the engine bay. If you havent already, you might as well just replace the entire cooling system. You will need to eventually especially if your car is a higher mileage car
![]() | VF Supercharged | Southbend Stage 2 Clutch | ZHP Cams | Technik Headers | |
#16 |
are you absolutely sure your mileage is that bad? that means you've dropped to like 10 mpg!
When you get to an empty tank, does your car take 15 gallons to fill? |
#17 |
OP,
Was it just painting work done.. Any painting in the engine bay? Or, was there also body work? Any welding?? How many miles is on your M3? |
#18 |
My Ride: ZHP Custom Stage 3.5
Sound like you boosted
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected |
#19 |
What if my temp gauge rises slightly on the highway?
#20 |
The trans controll module gets its load signal from the MAF sensor. Do not unplug your MAF and drive around.
