///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Old 09-05-2012, 01:07 PM   #1
TURBO_S2K
My Ride: 2003 M3 SMG
E46 M3 SMG Problem??
My car started to shift from 2nd to 4th??
It skips 3rd gear (both downshift and upshifts)
All the other gears are fine. Goes into every other gear fine
What might be the problem??
We changed the clutch but it didn't fix the problem
No weird noises come from the transmission or anything??
Here is a video I took today
TURBO_S2K is offline   Reply With Quote
Old 09-05-2012, 03:24 PM   #2
CW23
My Ride: E46 M3
Pump failure issue problem
Whatchamocallit.
///M
CW23 is offline   Reply With Quote
Old 09-05-2012, 04:23 PM   #3
TURBO_S2K
UPDATE!!
When I first start the car, everything is OK. Then if i drive te car a litttle harder, a yellow light on the right side of the dash pops up. Like a circle. And the car starts skipping gears. Not just 3rd. A different gear each time i start the car. Sometimes skips 2nd sometimes 3rd sometimes 4th
Also, when i upshift, if i keep my foot on the gas, the car won't shift. The gear starts blinking and i will have to release my foot off the gas so that it goes into the upper gear, and i can keep driving
Old 09-05-2012, 04:35 PM   #4
joeysm3
My Ride: ///M3 02
Gear position sensor and while ur at change the salmon relay too. the gear position sensor is around $350 relay is $12. make sure u bleed the system after you install the gps and while ur at it check if any of ur compression springs are broken. goodluck!
joeysm3 is offline   Reply With Quote
Old 09-05-2012, 04:44 PM   #5
TURBO_S2K
I don't want to change the smg pump if that's the problem %100
So is it the gear position sensor? Or is it the smg pump?
BTW, where is the gear position sensor located?
Old 09-05-2012, 05:01 PM   #6
ECSTuning
ECSTuning's Avatar
My Ride: BMW
You're symptoms are some of those associated with a failing gear position sensor. The gear position sensor is part 2 in the below diagram to give you an idea of where it is located. As stated above I would also go ahead and replace the SMG salmon relay as well.
Old 09-05-2012, 06:17 PM   #7
TURBO_S2K
what happens when the pump fails?
what are the symptoms for it?
just want to check it the symptoms for them are similar to my problem
the symptoms of the gear position sensor sounds just like my problem but from what I read, when the position sensor fails, the car starts shifting from 2 to 5 or you can only use like Reverse, 2nd, 5th and 6th
My car shifts to all gears when you first start it but after a little drive, it will skip only 1 gear. That gear is sometimes 4th, sometimes, 3rd and sometimes 2nd (until now)
And if will keep skipping that same gear. Meaning, when the light comes on and starts skipping 3rd, is always skips 3rd. Then when I stop the car, start it again, that yellow light goes and goes into every gear fine (but with that blinking problem), and then if it skips 4th, it will only skip 4th until I stop the car again
what about that yellow light that comes on the dash?
the one on the far right of the picture below (the circle with the exclamation mark in it)
http://anlasma-LINK-BLOCKED-images/b...ash-lights.jpg
Old 09-05-2012, 10:44 PM   #8
$ilent ///M
My Ride: 03.5 M3 smg lsb
Also check out the compression springs
$ilent ///M is offline   Reply With Quote
Old 09-05-2012, 11:10 PM   #9
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
Compression springs first, Gear Posiion sensor second. Find someone local or a shop that can read BMW / SMG fault codes.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 09-05-2012, 11:10 PM   #10
bryosb
My Ride: 2004 M3 Convertible
second that ^^^^^
There is four of em:
02 Part Number: 23311228393
06 Part Number: 23111222720
09 Part Number: 23317511337
15 Part Number: 23311228405
http://www.realoem.com/bmw/showparts...87&hg=23&fg=15
No Bucks ~ No Buck Rogers
***///M3 04 SMG Xenon, NAV,Cold Weather Pkg,HK Sound, CD Changer***
bryosb is offline   Reply With Quote
Old 09-06-2012, 02:26 PM   #11
TURBO_S2K
the car does not drop out of gear
like I said, the symptoms sound like the position sensor but I want to make sure because with a failed position sensor, it says the car will shift from 2nd to 5th and only go into R-2-5-6
My car only skips one gear when the automatic tramsmission light comes on
and it goes back to normal if i turn it off and start it again
can someone tell me the smg pump failure symptoms??
Old 08-28-2014, 08:24 PM   #12
sina518
My Ride: E46 M3
i know this is a old ass thread but was their a solution to this?
sina518 is offline   Reply With Quote
