Old 09-06-2012, 10:23 AM   #1
swaggerwagon
My Ride: 2005 330i
Any last words before I dive in
I'm about to do a driveway special with 4 jack stands and 2 jacks.
I'm doing a clutch and fly wheel install and pulling the tranny all the way out to replace the fluid and seals and check the gears. Its a 6 spd. I have BMW repair instructions for the process are there any suggestions or tips I should know before I go at this.
330i ZHP
3 Pedals FTW
BMW level 2 Tech
Ebay headers | Long tube CAI | modbargains ///M pedal covers | SS clutch line | CDV removed | Turner camber arms | Meyle HD FCABs | uuc poly motor/trans mounts | Eurospec Muffler | Clutch masters Stage 2 with aluminum flywheel | Coilover kit | CSL front bumper | Z4m shift lever | VISracing CF hood | Depo HID w/CCFL halo rings
swaggerwagon is offline   Reply With Quote
Old 09-06-2012, 10:31 AM   #2
aikmanson
My Ride: E30
Just take her slow and make sure you double check everything on the jacking process.
Never done this before on a BMW, but done it a few times on other cars.
Good luck.
1990 BMW 325is - Stroker Build
2010 MINI Cooper S
1995 Saab 900 SE - JZW Stage 4
aikmanson is offline   Reply With Quote
Old 09-06-2012, 11:19 AM   #3
Sweetness
My Ride: '01 325i
Good luck. You should be done by 9 tonight.
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 09-06-2012, 03:37 PM   #4
Paul180
My Ride: 2003 330ci
1) The entire transmission can be held in place by the dowel pin on the starter. I just used a large screwdriver and some PB Blaster from the top of the engine compartment to separate them.
2) Jacking up the front of the engine (make sure to remove all items in the way per the manual) will make removing/installing the transmission much easier.
3) Make sure you align the starter properly onto the flywheel to ensure that it will engage properly. I should be easy to feel/see if it's right or not.
4) Having a second set of hands will make everything much easier, especially when you're removing and installing the transmission. Doing everything by yourself is possible, just more difficult and time consuming (tranny is very heavy and akward).
Paul180 is offline   Reply With Quote
Old 09-06-2012, 04:18 PM   #5
mystert
My Ride: 2003 330Ci
There is a bolt that holds the flywheel cover on that goes in from the front of the car on the passenger side. All the other bolts come out the back.. Mine was covered in dirt and pulled and pulled on the transmission for an hour or so trying to get it loose. Once I realized that bolt was there and took it out, it slid right out. I think its a 10mm.
MysterT Huntington Beach, CA
mystert is offline   Reply With Quote
Old 09-06-2012, 06:54 PM   #6
swaggerwagon
My Ride: 2005 330i
I got all the bolts out and the trans is separated but fully supported on a jack. the starter wont seem to separate and is holding the whole thing together. i cant get a screw driver up in there. any suggestions
330i ZHP
3 Pedals FTW
BMW level 2 Tech
