Old 09-06-2012, 12:44 PM   #1
SpoonerDee
My Ride: 2005 E46
How to disassemble the auto shift knob.
To get this straight, I know how to remove the knob. That part was surprisingly simple (required little force).
What I need to know is how to take the knob apart and get that little rod off the old shifter to put on the new one I have. I know I can still drive the car with a new knob with no rod, but I don't like the fact that the knob can move so freely now.
So does anyone know how to take it apart?
I have tried searching but all I can find are threads on how to remove it from the center console.
SpoonerDee is offline   Reply With Quote
Old 09-07-2012, 05:49 AM   #2
SpoonerDee
My Ride: 2005 E46
Edit: Here is how
Okay with the help of a light, a flat head screw driver, some patience and a little bit of bravery I figured it out.
First remove the knob from car by putting the key in, turn to position two (do not turn car on) put the car in drive and put on the ebrake.
With the help from the gods, pull with all your strength and yank that sucker off, careful not to crack your windshield or your face.
Now go to a well lit area and get a flash light, and a flat head screw driver.
Here is the culprit
Turn the knob upside down and under the button you notice a slot. If you aim the light behind there you can see that the rod sits on a metal pin. As you depress the button, the metal pin goes up, pulling the rod up.
Now with take the flat head screw driver (you may want to use a thin cloth as well if you're afraid of marring up the plastic or wood) and put it into the slot.
With the screw driver in the slot, pry it out towards you. I found that since this knob had never been taken apart before it was in there really tight. So I pried it out a bit, the pushed it back in then pried it out a bit again (kind of like wiggling it) until the beast finally let go.
Once the button is out the rod will simply fall out. Pictured here is the hole in the rod and the metal pin it sits on
Now to reassemble the knob or transfer the rod to your new and improved shift knob start by inserting the rod into the knob (man this sounds dirty) until you see the hole of the rod in the opening of the knob (gettin kinda steamy in here ).
Now slide your button back into place and using your flashlight line up the metal pin with the hole in the rod. Take your time with this.
Once you feel you're in the right place, simply push the button in as if you were shifting and bam, you are done. Mine isn't totally finished in the last picture so the button is sticking out a bit. Don't worry once done it will look totally normal again.
And for those curious about the inside of the normal wood knob have a look.
Now that your new knob is together go back to your car, slide it on then with a good whack from your fist, slam it back down into place and enjoy!
