Old 09-06-2012, 10:54 PM   #1
Barneyhyphen
My Ride: 2004 M3 Convertible
Couple of head/gasket questions
Elring or reinze head gasket?
147k miles, if skim is 5 thou or less, should I use the oversized (1mm) gasket?
Should I use lube, locktite or anti seize on the head bolts?
Thanks.
BH
Barneyhyphen is offline   Reply With Quote
Old 09-06-2012, 11:48 PM   #2
Steven747
My Ride: 05 330ci
ummmm
no idea
Old 09-07-2012, 11:20 AM   #3
Barneyhyphen
head apparently needs 15 thou skim so propose using +0.3mm (+12 thou) head gasket.
Valves in good shape but a touch sloppy in the guides so will replace the exhaust guides whilst it's out. All valves being reground and lapped.
How polished should I get the block gasket surface? Just clean or looking like a mirror?
Thanks.
BH
Old 09-07-2012, 11:48 AM   #4
Mctwist77
My Ride: '99' BMW 323i
Why are you replacing the head?
Photobucket
BMW 323I 5 Speed
Mctwist77 is offline   Reply With Quote
Old 09-07-2012, 11:54 AM   #5
Barneyhyphen
Not replacing the head, just the head gasket. Overheated for PO and bought it from him as such.
He had been told by local "import specialist" that he needed a new VANOS but he actually needed a new head gasket!
Head is off and at the machine shop now. Being skimmed 15thou, all valves being reground and exhaust guides replaced.
Because of fairly heavy required skim, I will be using an oversized head gasket when reconstructing.
BH
Old 09-07-2012, 01:14 PM   #6
Mau330i
My Ride: '02 330i
I'm sure Mango or Dmax are going to chime in....
If you bought the car with the head removed i think there is the risk that the block threads for the head bolts are damaged.... (don't ask me how I know)
http://forum.e46fanatics.com/showthr...493&highlight=
Good Luck!!!
Mau330i is offline   Reply With Quote
Old 09-07-2012, 01:19 PM   #7
lakedude90
My Ride: 03' 325i
he didnt say he bought it with the head already removed. Just that the head was off and at the machine shop
_____________
Jacob
03' 325i
lakedude90 is offline   Reply With Quote
Old 09-07-2012, 02:03 PM   #8
Barneyhyphen
No, car was purchased with engine complete and intact, (other than blown head gasket). I stripped it down last week and took the head to the shop Wednesday.
I am aware that there MAY be a block thread problem and propose using Time-serts in block, if necessary.
Any answers to my original questions?....
1) Elring K or Reinz head gasket? any thoughts (will be using oversized 1mm HG as head needs 15 thou taken off)
2) Lube/anti-seize/Thread locker on head bolts?
3) do I need to polish the block gasket face to a mirror finish or just very clean?
Thanks.
BH
Old 09-07-2012, 02:11 PM   #9
Zell
Zell's Avatar
My Ride: so turbo wow
1. You can do one or the other. Both are OEM suppliers. You won't go wrong with either. Just look on different sites and get the cheaper one.
2. Bentley does not say anything about using thread locker, but it does say you should lightly lubricate the head bolts.
I can't comment on #3, I have no idea.
Old 09-07-2012, 02:14 PM   #10
Brinkley
My Ride: 99 328i, 07 z4 3.0
#3 Just very clean should be fine, remove anything obvious, and get it good n clean. Mirror finish? nah.
Brinkley is offline   Reply With Quote
Old 09-07-2012, 07:22 PM   #11
Barneyhyphen
Thanks all.
Difference in HG price for the oversized 1mm HG seems quite extreme but I have to say, for some unknown reason, I want to go with the EK?
Just one last question....looking at the head from the front of the car, in the middle of the top surface of the head is a cam chain rail (for the cam to cam front chain). The left of the two torx bolts holding this rail down, is fairly short and screws in to just the head but the right bolt passes through the head and screws in to the block. Can anyone advise the dia/pitch/length of that bolt please? Realoem is a little unclear! could it be an M6x100?
BH
Old 09-08-2012, 09:27 PM   #12
Mau330i
My Ride: '02 330i
Yes, it is M6x100
Part number: 11 12 1 720 731
Supplement
M6X100
Hope this helps
Old 09-08-2012, 09:36 PM   #13
sammk
My Ride: Bone-stock E92
And when you are putting everything back together, not sure how you're planning to re-time it, but there was someone on here recently who said he had to tweak the timing a few times to address a cam fault and in the end he had to be off by a tooth from where the manual said for everything to be happy.. Seemed like the cam diagnostics are a little too touchy on this motor or the manual was incorrect..
E92 convert. BMW Fanatic.
sammk is offline   Reply With Quote
Old 09-08-2012, 09:41 PM   #14
Mau330i
My Ride: '02 330i
For the reassembly and timing I used a great thread by JJRICHAR and it working great.
http://forum.e46fanatics.com/showthread.php?t=899347
Old 09-08-2012, 09:56 PM   #15
sammk
Great reference!
Old 09-10-2012, 10:40 AM   #16
Barneyhyphen
Thanks all for the constructive advice and confirmation. All very much appreciated.
BH
