Old 10-04-2012, 03:34 PM   #1
e46amazed
My Ride: M3
Question Removing headliner trim covering third brake light?
Is there a thread out there describing how to remove the trim piece that covers the third brake light in the interior above the rear seats? I couldn't find anything with specific instructions.
Part #4:
http://realoem.com/bmw/showparts.do?...36&hg=51&fg=40
http://www.ecstuning.com/Search/51448202872/ES115730/
Oh and also does anyone have instructions for removal of the C-Pillar handy. Like an idiot, I am stumped on removing the light from the C-Pillar, which seems key to removing the C-Pillar. I just don't want to brake anything that I don't have to
Thanks!
e46amazed is offline   Reply With Quote
Old 10-05-2012, 12:11 PM   #2
e46amazed
My Ride: M3
Anyone?
Old 10-05-2012, 12:21 PM   #3
My Ride: 2016 Lexus
On the third brake light, I'm interested too. I want to clean mine.
On the c-pillar, if you're a coupe, there's a torx bolt behind the light holding the pillar on to the steel c-pillar. Careful you don't snap this! On sedans, you can pull the c pillar panel right off with your fingers (no torx bolt holding it on)
As for the light, just carefully use a flat blade screw driver to lift on the bottom edge of it. Carefully. thinner the blade the better. The light just pops off and back on with a spring. after you remove that torx bolt behind the light, just pull the panel hard with your fingers. Fully pop open the window and pull the felt trim off the area you're working on.
Old 10-05-2012, 12:21 PM   #4
Marek555
My Ride: E46 328i 174kW
Just pull it gently off.
Marek555 is offline   Reply With Quote
Old 10-05-2012, 12:40 PM   #5
boongsin12
My Ride: none
^ +1
2001 330Ci
boongsin12 is offline   Reply With Quote
Old 10-05-2012, 12:57 PM   #6
Mctwist77
My Ride: '99' BMW 323i
Yup, just pulls right off
Photobucket
BMW 323I 5 Speed
Mctwist77 is offline   Reply With Quote
Old 10-05-2012, 01:36 PM   #7
kaldE46
My Ride: 2001 325i
Pop that ish off
kaldE46 is offline   Reply With Quote
