Sponsored by BimmerWorld
Old 09-30-2012, 04:06 PM   #21
Mc 007
My Ride: 325ci Performance
Originally Posted by Stinger9 View Post
Chart for comparing Sway Bars
Eibach front 27mm
Mc 007 is offline   Reply With Quote
Old 09-30-2012, 04:08 PM   #22
Stinger9
My Ride: '04 330Ci
Every mile of every day.
What the heck did I just say?
Old 09-30-2012, 04:12 PM   #23
Mc 007
thank you very much,i can get my Eibach kit this week
Old 10-02-2012, 06:28 AM   #24
J LAU
My Ride: E46 / E82 / E89
HUGE DIFFERENT!
I have the Eibach Anti-Roll Kit for F+R
27mm in the front
21mm in the rear
I think they are more effective than springs, especially on high speed corners.
J LAU is offline   Reply With Quote
Old 10-02-2012, 12:43 PM   #25
Mc 007
super,tomorrow i can test them on my car;-)
Old 10-03-2012, 04:37 AM   #26
Mc 007
5 min ago
[IMG] Uploaded with ImageShack.us[/IMG]
Old 10-03-2012, 10:54 AM   #27
Stinger9
My Ride: '04 330Ci
Easy to show in the box.
Harder to show on the car!
Did you get new links to put on at the same time?
Old 10-03-2012, 12:57 PM   #28
Mc 007
installed this afternoon,another drive,but i have do only a fast turn,tomorrow maybe more km test
Old 10-06-2012, 12:31 AM   #29
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
excited to hear your feedback
Old 10-07-2012, 01:29 PM   #30
Mc 007
fantastic,yesterday i do a test of 60km,another drive...i must learn to drive my car
Old 10-08-2012, 06:55 AM   #31
subieworx
My Ride: ZHP, 335, E53, E30
This chart is only relevant for solid sway bar sizing.
subieworx is offline   Reply With Quote
Old 10-08-2012, 08:41 AM   #32
Stinger9
My Ride: '04 330Ci
What kind do you have?
Old 10-08-2012, 08:02 PM   #33
subieworx
Stock.
A typical hollow bar has a .25" wall thickness and with lots of complicated math can be found to have a lower overall stiffness than a solid bar. Most 25mm bars have an equivalent stiffness to a solid 22mm.
Old 10-08-2012, 08:30 PM   #34
Stinger9
My Ride: '04 330Ci
True, they save steel and weight with a hollow bar because the torsional rigidity is derived mostly from the resistance to twisting of the steel at the outer part of the radius rather than the steel they 'remove' from the core.
How can you tell whether your bar is hollow or solid for sure?
Try a heavier bar sometime on your car. Very satisfying.
Why is the math more complicated than computing the rigidity for a solid bar and then subtracting the rigidity of a solid bar with the diameter of the hollow space within?
Old 10-08-2012, 08:40 PM   #35
subieworx
Think about that. If the bar was 25mm OD with .25" wall thickness that would mean that the inside diameter (hollow section) would be 12.3mm. That would leave an equivalent stiffness of 12.7mm i.e. the 25mm hollow bar is WAY less stiff that a stock 20mm bar. (all hypothetical bar sizes) The math is quite complicated.
My saying that a 25mm hollow is roughly equivalent to a 22mm solid is a gross oversimplification. The actual wheel rate of a bar is also influenced by the lever arm of the bar. A bar with a 12" lever arm is going to be much less stiff than a bar with a 1" lever arm as that arm (as measured from the center of the portion of the bar that spans the bushings) due to the mechanical advantage of the longer arm. Example: a 50mm bar with a 12" lever arm could actually have an equivalent stiffness that is less than a 10mm bar with a 1" lever arm. (just for reference and very likely not the case, but you get the point)
Old 10-08-2012, 09:11 PM   #36
Stinger9
My Ride: '04 330Ci
I did think about it. I don't think you understood my suggested methodology. Please re-read.
And
I normalized the length of the lever arm for comparative purposes. No need to factor them in.
Old 10-09-2012, 05:32 AM   #37
subieworx
Wasn't trying to be mean.
I understand what you said as I described in my example. The lever arm example was to help people further understand sway bars.
Old 10-12-2012, 07:02 PM   #38
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
My Hotchkis bars made a HUGE difference. And with my coilovers now the chassis has little to no roll. The limiting factor now is solely just my tires
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 10-13-2012, 09:59 AM   #39
dawnpatrol53
Banned User
My Ride: 2004 330ci
^x10,000
dawnpatrol53 is offline   Reply With Quote
Old 10-13-2012, 07:09 PM   #40
hokiebimmer
My Ride: 2003 BMW 330i ZHP
Just put hotchkis bars on my car today as well. HUGE difference
2007 335i Coupe: current
2003 330i ZHP: (for sale)
hokiebimmer is offline   Reply With Quote
