Old 07-31-2011, 12:58 PM   #1
intelone
My Ride: e46 M3
Sequential Turn Signal
Had a problem with my EE (Eagle Eyes) turn signal. Tore it apart, and decided to make them turn on in sequence. Turns out there was a bug in my tail light. Literally a bug; actually a moth to be exact. Don't know how that critter got in there. Did away with him with a vacuum. Finally done, up and running. What do you guys think?
For those who can program the LCM, are there provisions/codes that can lengthen the flash rate? As of now, the car's flash rate is my limiting factor. It has no problem with finishing its sequence, its the hold that won't latch on for long due to the car's own flash rate ending, preventing the microcontroller to finish its routine. If it can be done by programming the LCM's flash rate parameter, that's the route I will take. If not, I shall power the microcontroller on my protoboard independently of the turn signal, allow it to sequence on its own, ignore the second pulse, and go back to main. Well i'm done, beer time.
intelone is offline   Reply With Quote
Old 07-31-2011, 04:18 PM   #2
Milz328
My Ride: 2000 BMW 328i
Damn thats sick how long that take??
Milz328 is offline   Reply With Quote
Old 07-31-2011, 04:41 PM   #3
stevenluczynski
My Ride: Is Steel Blue
that's so awesome! DIY?
stevenluczynski is offline   Reply With Quote
Old 07-31-2011, 05:14 PM   #4
SPDSKTR
My Ride: E46 ZHP TS2+ Coupe
I want. Make me a set?
Originally Posted by Brucifer325 View Post
Thread sucks so bad they moved it to the Feedback Forum.
SPDSKTR is offline   Reply With Quote
Old 07-31-2011, 05:20 PM   #5
Apple4life
Apple4life's Avatar
My Ride: 03 325i SULEV
If you make one for sedan, let me know!!
Apple4life is offline   Reply With Quote
Old 07-31-2011, 05:36 PM   #6
jneumann
My Ride: 323i, 530i, Z4 3.0i
Send a message via AIM to jneumann
AVR? PIC? Source + schematics would be awesome.
E46 323i Sport/5 speed | 243k miles
E85 Z4 3.0i Sport/6 speed | 117k miles
E83 X3 3.0i M-Sport/6 speed | 130k miles
E39 530i M-Sport/5 speed | 237k miles
Member, Three Pedal Mafia | Long informative article on oil | BITOG German Castrol FAQ
jneumann is offline   Reply With Quote
Old 07-31-2011, 05:42 PM   #7
neil1138
I am truly impressed. If you made a kit with the needed components, I know I would buy one.
neil1138 is offline   Reply With Quote
Old 07-31-2011, 05:47 PM   #8
stevenluczynski
Originally Posted by jneumann View Post
avr? Pic? Source + schematics would be awesome.
+1111
Old 07-31-2011, 05:50 PM   #9
intelone
My Ride: e46 M3
I'm currently in prototyping and testing mode. I plan on making pcb boards for the controller needed to sequence the lights. As of now the protoboard fits inside a credit card sized plastic box, which I will pot to shield it way from the environment. I want to shrink its footprint down to size, add a jumper so the user will be able to switch from sequence mode to full on (stock) mode, add ribbon connects so that removing said controller simple for repairs a snap.
Now different company (eagle eyes, depo, etc ...) uses different LEDS in there lights which makes identifying the LEDs' properties mandatory. Also their array are set up differently. The array of turn pcb has to be modified. As you can tell, traces were cut, while others were made, surface mount transistors were overridden, and individual connection wires were soldered in. I plan on releasing a board for those with soldering/electronic's skill. I also plan on doing the retro for others who don't want to bother cutting up their lights.
Old 08-01-2011, 12:47 AM   #10
jneumann
Win! Sub'd!
Old 08-01-2011, 02:10 AM   #11
TerraPhantm
My Ride: M3 & ZHP
As far as I can tell, there's no way to adjust the speed of the blinkers via code. I've spent far more of my life studying the various LCM parameters than I should've, so I'm fairly confident it simply isn't possible.
TerraPhantm is online now   Reply With Quote
Old 08-01-2011, 02:58 AM   #12
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
Very Nice
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
Old 08-01-2011, 09:29 AM   #13
jneumann
Maybe have the tail lights "blink" at only half the normal rate, by having the microcontroller run the tails off a separate +12v lead, triggered by the normal tail light lines?
Old 08-01-2011, 09:40 AM   #14
intelone
My Ride: e46 M3
I think I have it, had to revisit an old forum. As the cap discharge it'll give enough time to finish sequencing and hold. The cap should keep the relay charged enough to hold. Plus i don't have to have the micro controller powered on forever. Pin 30 goes to the control box, then to the mc, then to the array.
Old 08-22-2011, 11:56 PM   #15
ianbiz
My Ride: E90
Send a message via AIM to ianbiz
Very cool! Oh btw, whats the first song? I'm replaying the video for the song right now lol
Ian
ianbiz is offline   Reply With Quote
Old 08-23-2011, 02:25 AM   #16
Tchleung
My Ride: 02 M3
Good old Shazam app...
Follow me on Instagram @tommtomm84
03 Carbon Black X5 4.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
456whp/312wtq @ 8psi, No #'s yet at 9psi
4.10 / Headers / ESS VT2-550+
Tchleung is offline   Reply With Quote
Old 08-23-2011, 10:26 PM   #17
ianbiz
My Ride: E90
Ian
Old 01-04-2012, 10:58 PM   #18
SaulCaldera
My Ride: M
I love this. It's something new that I haven't seen or heard of on an M3. I've seen this on newer mustangs and thought it would be cool to have it done on an M3. Anything new? Do you plan on making a DIY? or making these and selling them? Keep us updated. Good job man!
SaulCaldera is offline   Reply With Quote
Old 01-22-2012, 10:16 AM   #19
jratoll
My Ride: 330I
Very Nice
jratoll is offline   Reply With Quote
Old 03-25-2012, 03:03 AM   #20
Static///M3
My Ride: 2003 E46 M3
These are sick! I would def buy these
Static///M3 is offline   Reply With Quote
