Old 09-08-2012, 09:15 PM   #1
Nastrayus
My Ride: 2005, 325i
Question Opinions about an Engine Bore and Build for 05' 325i
I was thinking about doing a complete rebuild of my 325's engine. Based off of what I've researched I have the M54 model engine. Being all about power I was wanting to bore and stroke the engine just a wee bit to see if I can get a tad more juice.
However there are no purpose built kits for the non-M3 e46. Given that even the S54 is based on the M54 block and such would it be possible to use the kit here (a stroker kit from VAC for the S54) if I had the engine itself bored to 87mm.
I have a feeling this isn't possible, so my plan was to grab new pistons and do a .5 mm bore and try to scoop up the crankshaft from a 330i which has a longer stroke. Would the crank from the 330 be compatible with the 325?
Or even more to the point, would there be a god awful amount of work involved to make the crank compatible?
Thanks for any info!
Nastrayus is offline   Reply With Quote
Old 09-09-2012, 11:31 AM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
First, the S54 is not "based on" the M54 block. The S54 is iron and the M54 is aluminum.
Second, there simply isn't enough material to bore the M54 from 84 to 87 mm. IIRC, the max possible bore is 84.5.
While the 330 crank would be a direct swap, the remaining differences in intake manifold, etc would complicate tuning (ie, you would need an expensive custom tune). In the long run, it would be a lot less hassle and more cost effective to simply trade your 325 for a 330, swap in a complete b30, or add FI. Although a bit more involved, an S54 swap could also be a lot of fun.
Old 09-09-2012, 11:44 AM   #3
Iceman00
Banned User
My Ride: E90 6MT
Swap in a B30 and add cams+headwork, that's the easist route. Otherwise, leave the displacement stock and again, cams+headwork. Tuning can be handled from many places, but make sure you have one in mind before you tear into your car.
Old 09-09-2012, 12:28 PM   #4
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Either find a B30 or use the rotating assembly from one.
There are also guys using the 3.2 block from the E36 M3 with the dual vanos head from the M54. I'm fascinated by this and want to try it some day.
Old 09-09-2012, 01:24 PM   #5
wanganstyle
My Ride: e36 M3 / E30 GTS1
http://forums.bimmerforums.com/forum....php?t=1787170
s52 head modified to bolt in M54 double vanos parts.
S52 block (built) for turbo
Has been done overseas also with similar goals in mind (600rwhp e46 non-M turbo street bruiser)
Billet Original CNC LSD for 188K
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
E30 M20 2,7L Alpina + Euro E46 320D ZF 6 speed install
http://www.e30tech.com/forum/showthread.php?t=110010
wanganstyle is offline   Reply With Quote
Old 09-09-2012, 06:30 PM   #6
Nastrayus
My Ride: 2005, 325i
Ok thanks so much for the info! I think that I'll just see if I can find a b30 variant to bore .5 and then swap the whole rebuilt shebang into the car. Once again thanks!
3 series, 330, bore, cranks, rebuild
