E46 Convertible
Old 10-15-2012, 11:18 AM   #1
StoveTopp
My Ride: 330cic
Unhappy Please Help!
I'm new to this. But I have a '01 330cic with 201,000 miles. Back in July it started to stutter when I pressed on the gas. Then I pulled the car over and it was idling rough barely staying on. Shop picked it up and but they found other things to replace, vanos tubes, power steering pulley, and belts, and oil housing gasket. They said that later it needed ignition coils and a valve cover gasket but since they said bill was high enough that it can be done in the future. Well first of Oct. did it again, so I replaced the valve cover gasket and spark plugs myself but after researching should i do a compression test before i spend money on new coils? The shop never did a compression test or a leak down test. I was thinking of doing a compression test but am afraid of what the results may be that kind of miles. This is my first BMW and love it and don't know that much about them.
StoveTopp is offline   Reply With Quote
Old 10-15-2012, 03:21 PM   #2
sakumaxp
My Ride: 02 M3 convertible
vanos tubes? i didnt know the vanos had any tubes that connect to it...i had my vanos replaced for a little under $2,000.00 and if i recall it just hooks up to the front end of your motor, the vanos just constantly changes your valve timing if im not mistaken.
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 10-15-2012, 03:39 PM   #3
StoveTopp
My Ride: 330cic
Ok so no tubes( I don't know), but the vanos was replaced in July.
Old 10-15-2012, 03:41 PM   #4
generic
My Ride: 2002 BMW 330ci
Fuel pump I have an 02 330ci 150k miles and mine was doing the same thing then died it was the fuel pump, easy repair if you have basic tools and costs too much at a shop.
generic is offline   Reply With Quote
Old 10-15-2012, 06:14 PM   #5
johnrando
My Ride: '06 330 CIC ZHP
Sounds like they are trying to run up a bill. Take it somewhere else for a sanity check. Vanos, fuel pump, vcg, coils are DIY, or at least cheaper than $2K if you don't DIY.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 10-15-2012, 06:24 PM   #6
jfoj
My Ride: 330CiC, M5, X5, E93
Check engine light? Trouble codes?
See the first 2 links below in my signature for some ideas.
Old 10-15-2012, 08:08 PM   #7
omroalansari
My Ride: 2006 BMW 330ci
How much did these repairs cost? And where are you from? I have a 330cic 2006
Sent from my GT-I9300 using Bimmer App
omroalansari is offline   Reply With Quote
Old 10-15-2012, 08:13 PM   #8
eddiewolfgang
My Ride: 325i sharked cai
The symptoms ur describing have nothing to do with leaking valve cover gasket or steering wheel pulley. You don't need to do a compression test, for what? Is it burning oil? Is white or blue smoke coming out the tail pipe?
Bad vanos adjusters or bad solenoid cause the car to idle rough or no start at all.
eddiewolfgang is offline   Reply With Quote
Old 10-15-2012, 08:15 PM   #9
eddiewolfgang
Check fault codes and check fuel pressure. This is where u should start first. Fuel pressure with ignition on should be about 5bar
