Old 09-10-2012, 08:31 PM   #1
a32axo
My Ride: 2004 bmw 330CI
car start without fan? Help!!!
Im looking for a coolant leak, I think thermostat screw wasnt tighten all the way, can i start car without fan and airbox and maf?
a32axo is offline   Reply With Quote
Old 09-10-2012, 09:09 PM   #2
a32axo
any help
anybody have an answer?
Old 09-10-2012, 09:28 PM   #3
REKLESS ROB
My Ride: 2004 325ci
Leave the MAF connected, you can run the car without the fan and air box. You should really just use a cooling system pressure tester. Good luck.
REKLESS ROB is offline   Reply With Quote
Old 09-10-2012, 10:12 PM   #4
joegr
My Ride: 2002 325i
If the air box isn't there, then it's better to unplug the MAF. That way, the PCM will know that it can't meter the air and will use defaults. If you plug in the MAF, but don't pass the intake air through it, the PCM will think the engine is getting very little air, so it will inject very little fuel, I assume.
joegr is offline   Reply With Quote
Old 09-10-2012, 10:17 PM   #5
a32axo
ok
Thank you guys, started the car and found the leak. Its coming from the thermostat electrical hole.
Old 09-10-2012, 10:21 PM   #6
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Yes, you can start the car without the mechanical fan, the airbox and the MAF. You could also leave the MAF on and it will meter the air. It doesn't know what is attached to it, it only measures the amount of air that passes thru it.
Joegr, your assumption is incorrect. The air will actually flow easier without the airbox. The ecm doesn't make any assumptions about the airbox, it is just using the MAF to calculate the volume of air.
BMWCaptain is offline   Reply With Quote
Old 09-10-2012, 11:27 PM   #7
joegr
My Ride: 2002 325i
Sorry, I'm used to the MAF being on the airbox of my other three cars. I forgot it stayed with the throttle body side of the intake on the BMW. On my other cars, with the airbox off, the MAF would be sitting to the side somewhere not metering any airflow into the engine.
