Old 09-11-2012, 02:36 PM   #1
kimchristiansen
My Ride: bmw 320i e46
Question rear diff question.....
I have in the last days noticed a light rumbling noise from the rear, really just a light sound....... so far. And then i remembered that i have a rear diff from my old 1990 E30 325i hidden away. Will i be able to fit this item on my 1998 E46 320i? By the way they are both manual tranmission
Kind Regards
Kim Christiansen Denmark
Last edited by kimchristiansen; 09-11-2012 at 02:38 PM. Reason: key-note forgotten
kimchristiansen is offline   Reply With Quote
Old 09-11-2012, 02:58 PM   #2
robin325ci
My Ride: Helrot 325Ci
I don't think it will fit. E30 and E36 diffs have different mounting points if I remember correctly
robin325ci is offline   Reply With Quote
Old 09-11-2012, 03:25 PM   #3
kimchristiansen
But will i be able to make it fit? Just wondering
Old 09-11-2012, 04:04 PM   #4
Alex323Ci
My Ride: M3 & 323Ci (sold)
i've seen race teams for weight reasons "make fit" just about any rear diff with a lot of custom work.
with that said i highly doubt the E30 diff would work without costly fabrication/work. in other words it'll cost you more to "make it work" than another used one. the E30 diff is a lot heavier as well.
not to mention your 320i probably takes the small pumpkin diff on top of it.
Old 09-11-2012, 04:13 PM   #5
shwagon
My Ride: 325it 5-speed
It will not fit and you will not be able to "make" it fit and save any money.
Originally Posted by Reedo302 View Post
What an unending cavalcade of rampant virgin Mom's-basement-dwelling douchebaggery... Wow.
My Gun Builds: AR-15, GSG-522-SD, Saiga 308
shwagon is offline   Reply With Quote
Old 09-13-2012, 01:36 PM   #6
kimchristiansen
okay, thank you all for you time
Old 09-13-2012, 02:14 PM   #7
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Of course you've checked the fluid levels and inspected bushings? There are something like 7 bushings in total...and then there's also the subframe issue. Have you inspected around your rear, rear axle carrier bushings for a tear in the sheetmetal?
Use good led flashlight...and clean up around the subframe bushings so you can see what's going on up there.
You know, I assume, to open fill plug before drain plug...and think you need a crush washer for them too. Look for leaks...could be one of the three seals or the rear gasket...mine has just started seeping slightly, but the level is fine.
Upcoming comedy shows: April 23, Tierney's Tavern, Montclair, NJ, 7:00 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
dmax is online now   Reply With Quote
rear diff, swap
