Sponsored by BimmerWorld
Old 09-11-2012, 10:58 PM   #1
PrecisionX
My Ride: 2002 330CI
Finally solved my brake dilemma. PFC Z Rated and Brembo
So I've solved my brake dilemma by ordering this front and rear set up from ecstuning. Brembo rotors and PFC Z Rated pads with ATE Super blue fluid. The pads in the picture are not the ones I bought.
PrecisionX is offline   Reply With Quote
Old 09-12-2012, 01:49 AM   #2
tock172
My Ride: '12 135i DCT
Good job. You chose quality parts and didn't waste money on slotted/drilled rotors that you don't need.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 09-12-2012, 04:32 AM   #3
M3LIKECHIPS
My Ride: Prius
Nice
M3LIKECHIPS is offline   Reply With Quote
Old 09-12-2012, 09:21 AM   #4
PrecisionX
My Ride: 2002 330CI
I changed the order, ditched the pads and went with PFC Z Rated, everything else is the same.
Old 09-12-2012, 10:25 AM   #5
daves325in2012
My Ride: 2004 330cic
I've actually went through a set of OEM pads on a pair of new OEM blanks, then once the OEM jurid pads were gone I put in a pair of pfc z-rated and I absolutely love how much grip and no fade I get when I sometimes need to race for work ;-)
These pads create a black, easier to wipe off dust which when compared to the rear OEM pads (still 50% life when I put on the z-rated in front) will dust 60% while the rears will dust 40%
So basically the dust on them is way down over OEM fronts and its a easier type to deal with when cleaning wheels.
Overall a great everyday pad that has really great features. They warm up within Prob. 5 min within the oem grip standards, before that 5min they aren't too bad very easy to just apply a small amount more pedal and be good with stopping without worrying.
After they're warm they are very crisp and easy to modulate it just adds on the the very amazing e46 engineering in pedal feel.
A++ pads! They're going on rear next
Sent from my DROIDX using Bimmer App
Mysticblau 330cic
Pretty Facelift on..PSS9\\Alpine 9855\\More
daves325in2012 is offline   Reply With Quote
Old 09-12-2012, 10:36 AM   #6
Drewfus2101
My Ride: N/A
I have this exact setup. Just installed it a few months back.
I don't like it as much as I did the OEM setup. I don't think it has as much grip as the OEM brakes did. I went though the break-in process after the zinc coating wore off the rotors, so I'm pretty sure that isn't the problem. I'm not really sure what is. But if I do the brakes again, I'm going OEM.
Drewfus2101 is offline   Reply With Quote
