General Off-Topic
Everything not about BMWs. Posts must be "primetime" safe and in good taste. You must be logged in to see sub-forums. Click here to browse all new posts. |
Rating:
#3621 | |
Does the Z10 have the notification LED still? I always thought that was a cool feature. |
#3622 | |
It's in accessibility.
#3623 | |
You can set the intervals for when the camera flashes for messages when using the jailbroken tweak to say maybe every 30 seconds if you have an unread message.
![]() Last edited by b0bab0i; 02-04-2013 at 12:49 PM. |
#3624 |
Jailbroken just now on iOS 6.1
Cant wait to change the settings that annoyed me with the stock iOS. Here is the software to jailbreak: http://www.evad3rs.net/2013/01/ios-6...oad-links.html Here is the guide: http://www.evad3rs.net/2013/01/ios-6...-iphone-5.html
![]() Last edited by trj; 02-04-2013 at 02:45 PM. |
#3625 | |
#3626 | ||
#3627 |
how the hell do you connect a bluetooth device to an ipad? it says paired on my phone but the ipad refuses to connect to it or something
#3628 |
cydia is working fine.
I just downloaded smsNinja, that was the primary reason for me to jailbreak. Now downloading sbsettings.
#3629 | |
You need to disconnect from the phone before the iPad will connect. |
#3630 |
i disconnected everything but the ipad and it still doesnt connect. is it because i cant type in the passcode or something? never had to do that before with anything else though
#3631 | |
What calendar do you use? Sumptin sexyuhr than the phone's built in calendar?
FS in SoCal - Thule 516 Prologue bike carrier --------------------------------------------------------------------------- ![]() |
#3632 |
You might have to reset the headset. I had one and I guess it had a limit to how many things it could connect to. It was in the user manual on how to reset it, and after I did that, it worked fine.
- Alex
#3633 | |
I haven't fully got into using my phone as my calendar yet. I like this better than iCal though. |
#3634 |
**** that. i dont use the ipad enough to reset my phone. thanks for the heads up though
#3635 | |
Mine could pair with up to 5 things (I got it used), and when I got the bluetooth it wouldn't connect. Reset it (30 second process), and it worked great!
- Alex
#3636 |
bluetooth was reset. the problem is on the ipads side. oh well, pos just doesnt work
#3637 | |||
Bad iOS 6.1 Battery Life, Other Bugs Plague iOS 6.1 Users http://www.gottabemobile.com/2013/02...ios-6-1-users/ Quote:
#3638 |
I'm on 6.1 and battery life is fine for me. Slightly less than 6.0.1 (which was the best battery life for me), but there are so many variables it is effectively the same.
People complain about this every time there is a new update. What is probably happening is that people or the phones are backing up/restoring/syncing after the update, and the battery is draining as a consequence of that, not the update itself. I think the only legitimate complaint was for 6.0, as there was a problem where it would switch to LTE even when you had wifi when you were asleep. 6.0.1 fixed that problem. However, I did notice the same problem once when I was on 6.0.2. The battery life overall was fine, but it showed LTE when I woke my phone up and I was connected to wifi. So I'm not sure if the problem crept back in. I've gone something like 2 days on standby, and 8-10 hours of usage. Wifi most of the time, but the phone wasn't babied otherwise. I just use it when I need it. That includes leaving it unplugged overnight while I sleep. I have noticed that on 6.0.1, it drained maybe 1% overnight, but now it is 5%+. I am running trillian now, though, so it's an uncontrolled for variable. Last edited by alphawhiskey; 02-06-2013 at 09:53 PM. |
#3639 | |
But I wouldn't call 1% to 5% "essentially the same". It's 5 times more (on standby). |
#3640 |
Battery life got better for me? Whiners jk
-Brandon
:eeps: |
| Rate This Thread | |
