replace factory ballast with aftermarket - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-12-2012, 04:38 PM   #1
Essing
My Ride: 2004 325xi
Last winter I had issues with flickering and failure of my passenger side factory xenon. Did lot of search, research and troubleshooting. Checked the ground connections, swapped bulbs, swapped ballasts, swapped ignitors. I could not isolate the problem. I finally said screw it and plugged in a Morimoto 3Five ballast. All works fine and has for 6 months plus.
My solution for sealing the projector innards from the elements (due to the ballast wire to the bulb connection) is not elegant and a temporary solution at best. I'd like to incorporate the factory black dome/seal if possible. Swapping bulbs etc means removing a bunch of tape and plastic.
I'm looking for ideas to do this in a more permanent way. For those that have tackled this one, any thoughts are appreciated.
2004 330xi 6spd
2003 325i 5 spd
2003 325i 5 spd
2007 335i 6 spd
1985 635 Euro csi 5 spd
1986 535i 5 spd
1984 320i Baur 5 spd
1981 323i Euro 5 spd
Essing is offline   Reply With Quote
Old 09-20-2012, 11:05 AM   #2
Essing
My Ride: 2004 325xi
Wow after >125 views nothing.
If figured out the fix. The ballasts that I have (morimoto 3five) with d2s output plug is too bulky and not practical to seal through a grommet. TRS sell ballasts with Amp fitting rather than D2S fitting. That combined with a adapter with D2S on one end and Amp on the other does the trick
I'll have a pair of D2S Morimoto 3Five ballasts for anyone interested.
-Bill
2004 330xi 6spd
2003 325i 5 spd
2003 325i 5 spd
2007 335i 6 spd
1986 535i 5 spd
Old 10-02-2012, 08:43 PM   #3
pifane
My Ride: Many
I still have the same problem avec replacing air intake. I unpluged ground and I think that I damaged something by doing this because battery was unplugged and I played in the hood for 2 hours, arround the light, moving wire and etc.....
pifane is offline   Reply With Quote
