#1 |
Integrated phone in 01 E46 M3
Hey guys, so I got an 01' E46 M3 and I noticed that on my steering wheel is a button with the icon of a man talking into a phone. And I also have the microphone above my head where the garage door opener is located. I wanted to wire my phone into it so I can be hands free when I pick up a call, but i've changed my 2001 business CD unit to a 2002 330xi business CD unit so I could make an auxiliary. (long story, but I did it) So I don't know if I might have had to access it from that, but I have no idea where to even start. I've looked in the BMW manuals and doesn't give nearly enough information to do anything. I've been looking around but can't really find how.
Can anyone help me out? Thanks! |
#2 |
My Ride: Touring, and others
You are going to need something like the Parrott CK3000 and the interface kit from the UK to make it work. I've had this system in my Touring for several years now, and it works like a champ. Cost was somewhere around 100 bucks for everything.
[/SIGPIC]I'm fluent in 3 languages:
English Sarcasm Profanity |
#3 |
My Ride: '06 330CiC, '03 M5
Or you could see if you could find a TCU or ULF and retrofit the car. This will not be cheap unless you find a new E46 or X3/X5 that has the proper TCU or ULF.
See this site for more info - http://www.bimmernav.com/
Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501 Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491 Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619 E46/E39 GM5 Door Lock Info - www.bmwgm5.com Lower hose fan switch O-ring - BMW #13621743299 |
#4 | |
#5 |
Delmarco has a huge write up on the DIY.....search it out. He tells you everything you need.
