Old 10-02-2012, 09:31 AM   #41
WDE46
My Ride: '13 128i, '04 330Ci
Originally Posted by yo_marc View Post
Also...
What exactly are people doing in their cars when the fans explode?
Is the fan clutch engaged? What RPM's?
I find it hard to believe these things just let go and cause this kind of damage.
Like Alex said, it's probably caused by another part going bad and sending some sort of shock to the fan. Engine mounts allowing excessive play, pulleys seizing or breaking, water pump seizing, bearing wear, etc. There is no way the fan just explodes if it has nto been hit off axis in some manner.
Old 10-02-2012, 09:59 AM   #42
BMWboi
My Ride: 04 330ci 6spd
God i thought stuff like this would be a thing of the past after moving away from an e36
Sent from my GT-I9100M using Bimmer App
BMWboi is offline   Reply With Quote
Old 10-02-2012, 09:59 AM   #43
InlandEmpire325Guy
My Ride: 325 '01
good thing i did this to my car. same thing basically happened to me and i overheated twice!!!
____________________
-Tony
InlandEmpire325Guy is offline   Reply With Quote
Old 10-07-2012, 06:33 PM   #44
DRICHFL
My Ride: 330ci
FYI, once I removed the radiator I was amazed to see so much trash collected between the radiator and condenser.
I decided to replace the OEM BMW water pump with a Bosch water pump that has the metal impeller. In addition, all other parts are Genuine BMW oem parts. I replace the following:
Radiator
Thermostat
Expansion Tank
Mounting Plate
Fan Clutch
Fan Blade
Fan Shroud
Transmission Oil Cooler
4 Liters of Transmission Fluid Valvoline Maxlife
3.78 Liters Antifreeze Coolant G05
Items that still need to be replaced or repaired:
Damage done to the hood "several dents and chip paint"
Damage underhood insulation fire pad
Damage Belly Pan/Splash Pan
Damage Left and Right Brake Air Duct to support the belly pan.
I will go with the electric fan in the near future. I have driven the car over 700+ miles so far
ID:	472990   Click image for larger version
ID:	472991   Click image for larger version
ID:	472992   Click image for larger version
ID:	472994   Click image for larger version
DRICHFL is offline   Reply With Quote
