///M3 Forum
Old 02-14-2013, 01:14 PM   #41
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
I'm not sure what current alignment specs you are running but we setup e46 M3's with these specs for street driving:
-1.5 to -2.0 camber in the rear and zero the toe
Also, what tire pressures are you running in the rear?
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 02-14-2013, 01:20 PM   #42
andrey.kvotchenko
My Ride: 2001 m3 e46
Rear dampers??? What are u referring to??? And tire wear side to side is as even as it gets besides a tiny bit of edge wear on inside shoulder from the chamber!!!!
Sent from my DROID BIONIC using Bimmer App
andrey.kvotchenko is offline   Reply With Quote
Old 02-14-2013, 01:26 PM   #43
scca_ziptie
Rear dampers = shocks. Just confirming that the driver's side rear tire is wearing at the same rate and pattern as the passenger side tire? Inside tire wear is normal with any kind of negative camber.
Old 02-14-2013, 01:53 PM   #44
andrey.kvotchenko
O shocks lol... both tires wear the same
Old 02-14-2013, 02:00 PM   #45
scca_ziptie
Copy that, I feel like your dampers may be tired/dead but again it's tough to say without driving the car or physically seeing the car. Wish I could help more but if I were you I would find a shop that can verify the condition of them, then remove the rears and take them to the shop for verification.
-Don
Old 02-14-2013, 02:53 PM   #46
andrey.kvotchenko
I think ill do that let u guys kno
Old 02-15-2013, 08:11 PM   #47
andrey.kvotchenko
Soooo just ordered new shocks im also replacing my sway bar end links and while under there was going to do the mounts but i dont kno which ones to buy all the sway bar mounts are all different millimeters????
Old 02-17-2013, 12:24 PM   #48
Cookie Monster x6
My Ride: 2001 M3
Had some similar issues
Man,
I know you are in charlotte, but the guys here in Raleigh, 'import motorwerks' just did mine and everything is GTG now. Was going through tires every 800-1000 miles; and for me it was the RTAB. Might be worth it to call them and see who they recommend in Charlotte to take a look at it. Also, the guys here are great at giving advice and diagnosis.
These guys do some seriously awesome stuff; now that my tires are good I'm going to let them tune it this summer.
Cookie Monster x6 is offline   Reply With Quote
Old 02-22-2013, 07:50 PM   #49
andrey.kvotchenko
Thanks ill give em a call
