Sponsored by BAVSOUND
Old 02-28-2013, 10:50 AM   #1
325iGirl03
My Ride: 2003 325i
Exclamation AUX input question?
How do you hook up an AUX cable into the stock radio? Can you take the head unit out and hook it up in the back? (2003 325i)
325iGirl03 is offline   Reply With Quote
Old 02-28-2013, 10:52 AM   #2
patrickmurray2
My Ride: 2005 bmw 330i e46
If you have a 2002 and up I think it is there is a adapter for the oem bmw aux cable in the back and is probably the easiest thing you can do comes our with a couple screws
patrickmurray2 is offline   Reply With Quote
Old 02-28-2013, 10:53 AM   #3
325iGirl03
My Ride: 2003 325i
Thank you! Does it matter which end goes into the back of the unit?
Old 02-28-2013, 11:11 AM   #4
pawelgawel
My Ride: 330CI
i don't think you get the AUX cable your HU needs... search and it will be obvious which end goes where.
Sent from my SGH-I727R using Bimmer App
pawelgawel is offline   Reply With Quote
Old 02-28-2013, 11:15 AM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Buy the AUX cable that is needed for your radio They will say either no navigation or with or something like that. The instructions are on the paper and it can be installed only one way. Pop out the trim above the radio with a flat head, remove the radio which is held by two screws and just install the cable and run the other end to where you want it to go.
Old 02-28-2013, 11:17 AM   #6
sgoetz628
My Ride: 2002 330 CiC
Just wondering what you're planning to plug in back there. For years I've had an ipod adapter connected to the cable that was designed for the multiple cd player. Now the function for switching songs has stopped working and am thinking of getting a new one or something else.
As I recall, total install time was about 5 min!
I love my car as much today as the day I bought it
sgoetz628 is offline   Reply With Quote
Old 02-28-2013, 11:19 AM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
There's also this youtube vid
Old 02-28-2013, 12:02 PM   #8
patrickmurray2
Yes the end that plugs into the radio is a 12 pin connecter I thing or something like that and the other end is a female 3.5mm aux cable that you plug your regular aux cable into
Old 02-28-2013, 12:20 PM   #9
djantlive
My Ride: E46 M3
so where can i get this cable?
djantlive is offline   Reply With Quote
Old 02-28-2013, 12:28 PM   #10
tock172
My Ride: '12 135i Dinan S2
eBay for like $30 or so, or getbmwparts.com, ebmwparts.com, bmwpartssource.com
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 02-28-2013, 12:51 PM   #11
325iGirl03
My Ride: 2003 325i
Nice video, thanks. So the AUX will hang out of the head unit, correct?
Old 02-28-2013, 12:51 PM   #12
325iGirl03
My Ride: 2003 325i
The iPod cable is already attached through the glove box. I want the AUX cable so I can hook it up to my smartphone (through the headphone jack obv.) Maybe you should pop off the head unit and make sure it's still attached correctly. As he said, it has to be hooked up a certain way, so make sure the right side of the cable is hooked into the head unit.
Old 02-28-2013, 12:53 PM   #13
tock172
No, it will hang out of where you route the cable. Some people use the center console, ashtray, cupholders, etc while others use the predetermined mounting location in the glovebox. I used the glovebox so I can keep the wire stowed when not in use.
aux cable, diy aux input, e46 325i, head unit output, help!
