E46 Xi Forum
Old 09-14-2012, 12:35 PM   #1
E46er75
My Ride: 323i Vert, 330xi
Finally new wheels!
Just figured I would post some pics of my car seeing how I'm actually making some progress on it. Today I was able to finally put a new set of wheels on it just in time for winter! Seeing how I don't drive it much in the winter I guess it doesn't matter. I know your thinking and XI that doesn't get driven much in the winter what's the point. I actually like the handling of AWD and I love the E46 style...
Mods so far:
Eibach springs
Bilstein shocks
5mm pads in rear
Dynavin D90 V5
Dinan Intake
Clear Corners & Side Markers
Rear Tailight Upgrade (Not a fan amber)
ASA 18" GT-5
15mm Spacers (Added after pics were posted)
[IMG]Photobucket[/IMG]
Photobucket
E46er75 is offline   Reply With Quote
Old 09-14-2012, 12:41 PM   #2
ModBargains
ModBargains's Avatar
My Ride: M3
Nice clean OEM look! Congrats on the new wheels and suspension!
Blake Brunner|blake@ModBargains.com|(714) 582-3330 ext. 8011
We Specialize In:
BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts | BMW Tail Lights |
BMW Wheels | BMW Intake
Hours
Check out our Blog for updates!
ModBargains is offline   Reply With Quote
Old 09-14-2012, 01:14 PM   #3
E46er75
Thanks! I'm looking to buy front and rear M-Tech II bumpers soon. I just looked through your website I'm hoping to get them before winter. I'll keep ModBargains.com in mind!
Old 09-14-2012, 01:15 PM   #4
ModBargains
My Ride: M3
Thanks! We would love the opportunity to help you! Keep it up!
We Specialize In:
Hours
Old 09-14-2012, 01:17 PM   #5
TomTomTuning
My Ride: Black Sapphire ZHP
Looks great! I'm currently in the process of deciding on wheels for my Xi.
What are ".5mm pads in rear"?
Wheel spacers?
TomTomTuning is offline   Reply With Quote
Old 09-14-2012, 01:28 PM   #6
E46er75
Thanks. I didn't like how high the rear sat after I installed the new springs and shocks. The problem is that the stock XI come with larger upper spring pads, I believe they are 15mm pads. They can be replaced with 5mm pads which lower the rear around a 1/2" more.
No, I did not use wheel spacers.
Old 09-14-2012, 03:03 PM   #7
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
seems you could definitely use some spacers. Eibachs dont really drop it that much i see. I had h&r on mine and the gap was half what you have.
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 09-14-2012, 03:38 PM   #8
shadow 2
My Ride: 07 328i
Originally Posted by E46er75 View Post
Thanks. I didn't like how high the rear sat after I installed the new springs and shocks. The problem is that the stock XI come with larger upper spring pads, I believe they are 15mm pads. They can be replaced with .5mm pads which lower the rear around a 1/2" more.
Assume you mean 5 mm, not .5?
shadow 2 is offline   Reply With Quote
Old 09-14-2012, 03:58 PM   #9
E46er75
Yes sorry, (5 mm) is what i meant I kept thinking about the 1/2" or (.500) additional drop it added when I was writing the post.
Old 09-14-2012, 04:09 PM   #10
E46er75
I'm not looking for a big drop and Eibachs were just right for me. I would have used H&R's or possibly coilovers. But considering I'm getting older my days of slamming a car to the ground are over. I'm really not looking to scarfice comfort on this car just for looks. Although the stock suspension made me wondering what BMW was thinking on the 4X4 status. I did settle for the modest drop woth Eibach's. Plus i'm done with the harsh rides and younger crowds. I'm my only critic these days.
Great forum and thanks for the advice!
Old 09-14-2012, 04:23 PM   #11
E46er75
As far as the spacers go. How much spacing should be consider? I have seen sets in 5,12,15,20mm. I have noticed that the back wheels still sit a little in too far. The front seems ok to me. Can just the rears be spaced? Any advice would be appreciated. Thanks in advance!
Old 09-14-2012, 06:10 PM   #12
Rubirosa007
My Ride: 01 330Xi Silver Sprt
i just got some 15mm on my rear wheels and just ordered 15mm for the front aswell.
Rubirosa007 is offline   Reply With Quote
Old 09-14-2012, 06:17 PM   #13
E46er75
What size wheels and offset are you running?
Old 09-14-2012, 06:36 PM   #14
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
Nice choice of wheels for your car ( I would have stayed with 17s though for a little more tire sidewall). May I ask why you are considering spacers? Wheel spacers will set the wheels and tires outside the fender wheels more AND the tires could hit the top of the fenders when the suspension is compressed. Wheel spacers will also put some more load on the wheel bearings and the outer ball joint. And depending on which size spacers you get, you will have to also purchase longer lug bolts to get proper thread engagement to the hub. To help set those wheels off, think its time to treat the calipers to some paint (yeah, to me doesn't matter if they are stock calipers or not, color beats corrosion and rust when looking at the wheels and color on the calipers helps draw attention to the the wheels (my opinion and there are many here that think painting stock calipers is a waste). On my Black over Black '03 325 xi I used Beyern Mesh wheels, black with polished lip in 17 inch with Plus Zero Continental Extreme Contact DWs. Made for a nice look with cross-drilled rotors (all the non-braking surface painted black) and the calipers painted red. Makes the wheels pop.
tomoyer is offline   Reply With Quote
Old 09-14-2012, 07:27 PM   #15
E46er75
Thanks, I like 18" and think they are good fit for the E46 body style.
I have used spacer on other cars and never had a problem with wheel bearings. To be honest with you I have replaced more wheel bearings on non moded cars then moded ones. So this is the first time I have ever heard of wheel bearing failure linked to spacers. Also, ball joints might be an issues with a lower profile tires but once a again I don't beleive spacers will limit the longevity of the ball joints.
As far as the calipers go, i'm not a big fan of painting calibers and other components. To me it looks cheap and eventully looks worse as it ages. You can repaint but that only means painting over existing paint and then flaking/chipping starts. To me painted calipers look very cheap and make it look like a bad attempt at trying to make them look like big capiler upgraded brakes set. Don't take it personally it's just my opinion...
Old 09-27-2012, 11:57 PM   #16
Evo lol
My Ride: 03 330Xi
How do the eibachs ride compared to stock suspension? I had h and r and the ride was terrible
Evo lol is offline   Reply With Quote
Old 09-28-2012, 11:34 AM   #17
E46er75
Eibachs ride very similar to stock. Too be honest it's very hard to tell the difference. The only noticeable ride quality difference I have notice was switching to 18" wheels with 40 series tires. The ride is still great though and so far I'm pretty happy with all my mods.
I did consider h&r even though I have heard some negatives about ride quality. Too be honest the specs from H&R and eibach basically say the drops are similiar.
Old 09-28-2012, 12:43 PM   #18
Evo lol
My Ride: 03 330Xi
Really wish I bought eibachs. Instead I bought h&r and when those rode like crap i spent 400$ at the dealer for new sport springs. Running those with Bilstein sports. Ride still isn't that great. Back sits nice no wheel gap. Front on the other hand has to much wheel gap, so I bought the lowering spring perches. Hope it lowers it enough to stop driving me crazy. Guess we all learn from our mistakes. Oh and don't feel bad, I don't drive my xi in the rain let alone the snow lol
Old 09-28-2012, 05:40 PM   #19
E46er75
I have made some poor decision on other vehicles. This I actually did a lot of research through this forum as well as some others before buying my setup. I really was leaning toward h&r springs. But I realized I'm looking for the best comfort and a little wheel gap isn't all the bad.
Old 09-29-2012, 12:11 AM   #20
Evo lol
My Ride: 03 330Xi
Yea, tried doing all the research as well. Everyone said go with h&r. Now same people say I should of gone with eibachs. But your car looks great man.
