E46 Xi Forum
Old 09-14-2012, 05:02 PM   #1
ned cox
My Ride: 325xi 2003
transmission warning light
Any body dealt with transmission warning light? Car runs fine until I begin to slow down then it down shifts hard coming to a complete stop. There is no perceptable change coming up to speed. HELP
ned cox is offline   Reply With Quote
Old 10-03-2012, 10:52 PM   #2
staticbelow
My Ride: 2002 330xi
I have more or less the same issue. I just changed the thermostat because the service engine light came on and the dealer said that was why. (They also wanted $500 dollars to do it!) After installing the new thermostat on the way home the car started upshifting a little hard into 2 and 3, but the downshifts into 2 and 1 are really hard. I don't know if the new thermostat is related in any way but since it occurred after changing it I thought I'd mention it.
Anyone have any ideas? My car is a 2002 330xi with 99k.
staticbelow is offline   Reply With Quote
Old 10-04-2012, 10:17 AM   #3
SamDoe1
My Ride: 4cyl of fury
Change the fluid and filter. Change, do NOT flush. Very important.
Old 10-05-2012, 03:21 PM   #4
staticbelow
My Ride: 2002 330xi
SamDoe1,
Did that work for you? There seems to be a lot of back and forth about whether or not that is a good idea. I've read posts for about 2 hours now and it seems to be an even split between changing the fluid and filter, flushing the system, and people that say you shouldn't touch it at all. Could you supply a little background for your recommendation?
Old 10-06-2012, 11:24 AM   #5
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
Trans warning light is probably due to torque convertor lockup or maybe a bad maf (where it gets a load sensing from).
The harsh downshifts are fixed by a firmware update, we've done hundreds at work.
redbull 325is is offline   Reply With Quote
Old 10-06-2012, 04:04 PM   #6
White_Knuckles
My Ride: 2003 325xi
I'm in on the MAF. I changed out my Intake cam sensor and was instantly greeted with the Trans lamp on start-up! Um, I forgot to hook-up the MAF connector. Scared me good but never could figure what the @#$ MAF data has to do with transmissions? I thought the evil programmers at Siemens just liked to scare us.
RB's post helps understand why MAF "load" data is involved.
Old 10-17-2012, 09:13 PM   #7
staticbelow
My Ride: 2002 330xi
It turns out my problems were related to the MAF sensor too. When I plugged it back in it must not have clicked in all the way and came apart. Once I plugged it back in the hard downshifts disappeared. Thanks to everyone for the help. This forum continues to save me money
