Old 09-16-2012, 03:10 AM   #1
lilbimmer
My Ride: 01 330ci Step
Send a message via Yahoo to lilbimmer
Fault Code p1500
Causes my EML, DSC and handbrake lights to come on while driving. Car then goes into limp mode. A quick restart will clear the lights and the car will drive normally until they come back on 10 mins later. Although, when I took a short drive last night around 10.30p none of the lights came on and the car drove normally.
I did some research and some say it is the ICV stuck open (as per code). Others suggest cleaning/changing the MAF, but I also found the bmw equivalent DTC Code:17908 - Fuel Pump Relay Circuit Electrical Malfunction.
Where should I start looking before taking it into an indie shop? Please post links to DIY and/or pix - I would appreciate it. Thanks.
"sim simma, who gat di keys to mi bimma" - beenie man
lilbimmer is offline   Reply With Quote
Old 09-16-2012, 02:36 PM   #2
lilbimmer
Bump! Any ideas?
Old 09-20-2012, 03:19 PM   #3
lilbimmer
Did some research and found a few possible issues to the EML+DSC+BRAKE lights:
1. ICV
2. Throttle Body
3. Throttle Harness
4. Speed Sensor
5. ABS/ABS sensor
There were some other suggestions about the wheel sensor?? and I noticed, while driving today that my wheel was off-center. Again the p1500 code alluded to the ICV being stuck open. Any additional thoughts?
Old 09-20-2012, 05:49 PM   #4
Dippinwandy
My Ride: 325i
My car was saying icv jammed open so i replaced it with a used one from a member here but nothing changed.
Dippinwandy is offline   Reply With Quote
Old 09-20-2012, 05:58 PM   #5
lilbimmer
Yeah, I read posts that said they either changed the ICV or cleaned it, but the problem came back. So I am back to square one!
Old 09-20-2012, 06:04 PM   #6
Dippinwandy
My Ride: 325i
Well My problem started with a code for the maf . So i replaced it with an oem one. 5 miles later i got the eml and other lights. I read the codes and said jammed icv. I cleaned it . Didnt work. I replaced it, it still didnt work. I thought it was a bad maf so i got another one. Oem as well. Around 300 miles later the same things happened. So were in this together . Back to square one.
Old 09-20-2012, 07:41 PM   #7
lilbimmer
We sure are. Let's see if we can figure this out!
Old 09-22-2012, 12:51 AM   #8
Dippinwandy
My Ride: 325i
You should list the parts that you have replaced so far.!
Old 09-23-2012, 12:57 AM   #9
lilbimmer
OK. So I waited a couple of days before I posted this and I hope I did not jinx myself. Thursday night I decided to look under the hood to see if anything was out of the ordinary. I noticed the cover at the very front of the hood and just above the grill (please bare with me as I don't know the parts by name) that goes into what I assume the MAF?? was not put on correctly. Leaving a small gap for more air to pass through. I corrected this not thinking it would affect anything, but must say that after 2 days of driving no EML+DSC+BRAKE lights. SES light returned, but checked the codes - no p1500, just my typical "lean fuel" codes. I will post if everything changes.
Old 09-23-2012, 08:10 AM   #10
scarede46er
My Ride: 2001 BMW 325i ZSP
lilbimmer: I hope you have solved your problem, but it seems implausible that that was the issue. The MAF measures air after it has been filtered. Any extra air till the filter is not likely to affect MAF readings. Any experts: correct me if I am wrong?
Old 09-23-2012, 09:38 AM   #11
lilbimmer
You are probably right! I know I had to use quite a bit of effort to put it on correctly so I don't know if I "jiggled" anything back into place. Will post if the code or lights come back, hopefully it doesn't.
Old 09-25-2012, 10:22 AM   #12
lilbimmer
See link for update.
http://forum.e46fanatics.com/showthr...8#post14760578http://forum.e46fanatics.com/showthr...8#post14760578
