My car won't start - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 44 votes, 5.00 average. Display Modes
Old 09-16-2012, 11:19 AM   #1
Jamie018
My Ride: 1999 BMW 323i
Unhappy My car won't start
Hi guys
okay so it takes me a lot of tries to finally get my car to start. At first I thought it was the battery, but when I put the key in, the lights and radio, even the air conditioning system turns on. So. I went to autozone and the guy did a test and said that my battery was fine and the problem was the starter. So I took it to a mechanic and told him the problem. He said it's an easy fix, but he called me an hour later saying that my starter was fine (new). He then claimed that the problem was that everytime I got my oil changed, the mechanics who did it, never reset the system that keeps track of the miles of when I need my oil changed.
He then reset it but that didn't work. The car does the same thing. I put my key in, turn it everything turns on, but the car won't start. I have to keep doing that until it finally starts. It took me 20 minutes last time to finally get it to start!
Oh and i don't know if this matters but i followed the DIY on changing the 99 key fob to the diamond key fob, and i did that about a month or two ago. Could the problem be the key battery?
Jamie018 is offline   Reply With Quote
Old 09-16-2012, 11:26 AM   #2
adaseb
My Ride: 2002 BMW 320i
does it crank?
im confused because at first you say it doesn't start and then after 20 minutes it starts
adaseb is offline   Reply With Quote
Old 09-16-2012, 11:43 AM   #3
scarede46er
My Ride: 2001 BMW 325i ZSP
I think it is your key cylinder. Maybe needs cleaning lubrication or replacement. Do one thing, the next time you start the car, try and turn the key to ignition really hard (without breaking stuff obviously) and tell me if the car starts up immediately.
Old 09-16-2012, 12:04 PM   #4
Jamie018
Originally Posted by adaseb View Post
does it crank?
well i hear it doing a little rumbling? sound(maybe). i mean it's a very subtle sound unlike all the other cars when you try and start them
Old 09-16-2012, 01:06 PM   #5
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
You need to be more specific on what is happening.g when you try to start your car.
If you have done a search here, then you can tell us what you have done to narrow it down.
What is your battery voltage? At battety and at +B terminal under the hood.
Is there a CEL?
Fuel pump?
There is a lot you can check. Many have experienced this and discussed it.
Good luck.
BMWCaptain is online now   Reply With Quote
Old 09-16-2012, 02:46 PM   #6
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
It's a key issue. Key...or that ring around ignition (ews system, I think)...but I'm going with 'key.' Final random guess.
Ask me how I know!
Do you have another key...valet key? If not, order one.
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 09-16-2012, 02:58 PM   #7
scarede46er
If you are like me, you will not need a new key (although it's good to have a spare). First, soak the blade of your key in water and clean off all the dirt you can. Dry it off and then use some WD40 to soak the blade. Use a wire brush to scrape off every inch of it. Use paper towels to wipe off residue.. which should be black. Then spray some WD40 on to your lock cylinder, making sure to spray it from a distance so as to no concentrate it on one spot. Let it soak for 3-4 minutes. Spray some more onto your key and insert it in the lock wiggling and turning it several times to spread the liquid everywhere. Give it about 5 minutes to dry and then try starting it.
Old 09-16-2012, 02:59 PM   #8
TR4G-
My Ride: '01 325xi, '90 325iC
I too have has this problem for a year or so. But not to this extreme (happens once or twice a month) It will sometimes just not start... When I start the car everything happens normally except the car doesn't start, aka no cranking or turning over or anything like that. For me it's completely silent. I end up taking the key out and putting my car into neutral then first then try again. It's hit or miss and when it acts up its super annoying
I have a manual car, and Ive seen topics like this before and the solution has seemed to be either the key antenna or the ignition switch.
TR4G- is offline   Reply With Quote
Old 09-16-2012, 11:07 PM   #9
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
WD-40 is an excellent cleaner, but, never use that crap in a lock.
scottjoh is offline   Reply With Quote
Old 09-17-2012, 05:22 AM   #10
jfoj
My Ride: 330CiC, M5, X5, E93
I am starting to have no sympathy for any BMW owner with only 1 key. They are just being stupid because everything they lock their key in the trunk, break the driver door lock link or loose it, they are SOL!
So you probably have a few issues to choose from:
1. Your mechanic, well what can I say, he should be selling shoes. Mileage indicator had nothing to do with your no start condition.
2. My first guess is since you recently messed with your key, this may have something to do with your problem?
3. My second guess is you need a new ignition switch or EWS ring antenna? Ignition switch is about $60 in parts, EWS antenna ring is around $20 in parts?
4. PRNDL or clutch safety switch. If your car is a manual trans, next times the car will not start, keep the ignition switch in the start position and start pumping your clutch and push is all the way to the floor and see if this helps. If an automatic, with your foot on the brake, move the shifter from park to neutral.
5. Last item is you may have an EWS issue, but this is unlikely. Before I jumped all over the EWS, buy a new key. Do not buy a Valet key, get either a replacement key or replacement keyfob. Not sure if you will get a new or old style keyfob?? A diamond keyfob from a decent dealer that is not ripping you off is about $160. But again, unclear if the replacement for the early models is a diamond fob or not?
Old 08-08-2014, 02:55 PM   #11
geniukas5
My Ride: 320d
Hi,
I have same thing right now... and thing is I assume its something to do with immobilizer, cos I got to the fuel pump and when I turn key not every time it starts pumping fuel. Now I know every time when I will start or not cos I can hear pump working or not. I still haven't done anything diagnose it properly cos just finished yesterday eliminating other problems. I will try to give a good clean before I buy new key but maybe anyone have more ideas that are cheaper then new key? Maybe getting rid of immobilizer just to turn it of??
geniukas5 is offline   Reply With Quote
Old 08-08-2014, 06:54 PM   #12
David McMahon
My Ride: '99 E38 740iL
http://forum.e46fanatics.com/showthread.php?t=1011677
David McMahon is offline   Reply With Quote
Old 09-14-2014, 03:04 PM   #13
cwgonzalez1192
My Ride: 2004 330Ci
Hey guys, I'm having a similar issue; however, I have noticed a pattern:
Regular key w/ remote lock = No response to key turn (has become increasingly frequent lately, but usually I can wait a minute or two and have some luck eventually)
Valet key = Starts on first try (every time so far)
This obviously leads me to believe it has something to do with the electronics in the key but I'm new here and unfamiliar with what all is going on inside the key and the key / starter relationship. Could anyone provide some basic insight to those systems and maybe a diagnosis / prescription? Thanks!
cwgonzalez1192 is offline   Reply With Quote
Old 09-14-2014, 05:21 PM   #14
NumbaOneNewb
My Ride: 2003 330CI Silver
I'm having a hard time believing that any mechanic told you that a starter on this thing is an easy fix.
does anybody know if its even possible to get a good visual on the starter on our cars? I've yet to do mine but from all I read, it isn't fun. Let's just say it is new.
Wait a second. So how were you able to upgrade to the diamond key from the older style key? Ok, I see now. I think I know what the issue is. Let me ask you something. How were you able to keep the transponder fixed in position? From my experimentation with keys, I have had issues with my flip out key blade upgrade DIY that if the transponder is off by even 2mm, it will cause a silent non start issue. did you tape or glue the transponder into place?
It is extremely important that the transponder be in the correct position, and also, not move around. You need to find a way to keep it firmly in place. If it hasn't moved from where you last put it inside that key shell, perhaps moving it slightly in whatever direction to get it closer to the transponder reader ring thing will solve your problem.
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 12-13-2014, 06:11 PM   #15
HHI ED
My Ride: 328I
key turns but nothing happens ??
I have the same prob with my 2000 328I. How all this came to be ...My son locked the original electronic key in the trunk. So I called my dealer and they had a valet key made for $86, which just opens doors and turns ignition on. He used new valet key several times and now the electronic key does not work. Like many of you, we thought it was the battery but it checked fine. Had diagnostics and all was normal. So now I plan to call BMW and find out why the electronic key does not work anymore. ep
HHI ED is offline   Reply With Quote
Old 12-29-2014, 04:00 PM   #16
adamdelay
My Ride: 2002 M3
I have a 2002 BMW M3; and for the past few months I've been having problems with my car periodically having Issues starting. The last time was at the dealer the day I dropped it off to have it looked at after it wouldn't start the day before. Obviously, It worked fine driving in there and they were able to start and drive it three different times; before it stopped working again.
Not thinking anything of it; and wanting my house keys back, so the next day I gave them a spare. Since then, they have had no problems with the car starting.
They've been doing diagnostics on it all day, I called to see what progress they might have for me. To my surprise; the car has had zero problems starting... Perplexed I stated; Do you think it has something to do with the Key I gave you?
In a sudden 'ah - ha' moment; he said; MAYBE! Let me talk to the tech. and get back to you. I'm still waiting for a response but came across your post, and was wondering if it did in fact turn out to be your key.
Mine will lock and unlock the doors no problem; but has been requiring I get closer and closer to the car before finally doing so.
adamdelay is offline   Reply With Quote
Old 12-29-2014, 05:20 PM   #17
scottjoh
Modded ///Member
The electronics in the key to enable the starter is part of the EWS system and has nothing to do with the remote. The dealer can and SHOULD have read the fault codes from the EWS module in the car. If an attempt to start the engine without a working EWS key it will log a fault and they will know right away. Idiots sound like they did not read the faults. The EWS in your key sounds like it is going bad. It is very nice to have another key in case this happens. Once the car authenticates and enables the starter you need to remove the key and wait 30 seconds before the car deauthenticates. Many people get all confused because the suspect bad key works ( when a good key is used within 30 seconds prior to the bad key)
Old 04-28-2015, 08:39 AM   #18
adamdelay
My Ride: 2002 M3
Unfortunately my issue turned out to be much greater than anticipated. For some reason, and a bit of an 'egg on the face' moment for the dealer; they were using outdated fault codes to try to figure out what the problem was. After realizing their codes didn't make sense, and in some cases not showing up at all, they realized their was recently an update provided by BMW corp. for the fault codes. Next time you see your dealer, ask them when they last updated their system!
After spending nearly $4K in repairs on my beast, they finally found the real issue; The Transmission (SMG) transponder was faulty. A $2K fix, to which they warned, this could be a sign the transmission is ready to quit all together; which would be another $5K if I needed a new tranny... After owning my baby for only two years and spending as much as I had on her to keep her running, I had to give in and move on.
Good Luck guys and gals.
Old 04-28-2015, 03:03 PM   #19
CharlieFoxtrot
My Ride: 02 330Ci
I'm sorry to hear that. I'm also sorry your dealer charged you $4k for repairs that you did not need. I'd be looking for a refund if I were you.
A polite, intelligent, clear and concise letter to the dealership general manager and owner may help, briefly explaining the problem with the car, and detailing the attempted repairs and mistakes made by the dealer techs. Also find names and addresses for the dealership group's corporate executives (if applicable), BMWUSA VP of sales, VP of service, VP of dealer relations, and any other bigwig who might matter. Put those names & addresses on the letter too, so the dealer knows you can cause potential trouble for him. Then take the letter to the dealer _before_ sending to the bigwigs, and see what happens. It worked perfectly for me at a Cadillac dealer.
kevin
CharlieFoxtrot is offline   Reply With Quote
Old 11-25-2015, 07:27 PM   #20
ghyde
My Ride: 2005 325Ci, Sport Pk
Problem solved: bad ignition switch
Had similar problems. A few times a month I turned the ignition key but absolutely nothing happened. Then it progressed to not starting once a week and eventually too frequent to mess with. Tested the starter and it was fine (see: http://forum.e46fanatics.com/showthread.php?t=1011677).
Took a gamble and replaced the ignition switch (not the key cylinder) and problem solved. The switch cost about $55 from pelicanparts.com and only took an easy 10 minutes to install. Problem solved!
ghyde is offline   Reply With Quote
323i, bmw, won't start
