Old 09-16-2012, 11:50 AM   #1
johndddd
My Ride: 02 m-3
xenon headlight shrouds removal
Does anyone have a DIY of a OEM xenon projector shround removal, mine are aging and starting to flake I would like to remove JUST the shrouds, however not sure if they can be removed or is the reflector lenses all one molded piece?
johndddd is offline   Reply With Quote
Old 09-16-2012, 01:21 PM   #2
haurelio
My Ride: 2001 bmw 325i
they are clip on. very easy to remove..
Old 09-16-2012, 06:30 PM   #3
johndddd
My Ride: 02 m-3
Are the shrouds specific fit, Do you know if you need left and right shrouds? I Never replaced this before. These eBay shrouds don't say and I don't want to go through the time and effort only to find out I need side specific. I remember someone saying he had two rights at one time and this guy needed a left. It was a long time ago.
Old 09-16-2012, 10:33 PM   #4
haurelio
I don't think so, I can't really recall. Another Idea will be to Repaint them, Just make sure you choose a High temp spray paint..
Old 09-18-2012, 03:32 AM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Paint them black or get new ones from www.theretrofitsource.com
Old 09-19-2012, 06:42 AM   #6
johndddd
My Ride: 02 m-3
Thanks for the link Jake, I ordered the e46R's
Old 09-19-2012, 11:56 AM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
And in regards to your PM, the shrouds are held on by clips, but you have to remove the projector from the headlight housing
Old 09-19-2012, 12:25 PM   #8
johndddd
My Ride: 02 m-3
Oh **** I'll never go through all that hassel, I thought all I would have to do is pull them off, and snap on the new ones. If I pull them off and break the clips on the back I would think "so what" I'm not going to reuse them. Then push on the new ones. Will this work?
Old 09-19-2012, 12:34 PM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
Yup, you can break them off carefully and just push in the new shrouds.
Old 09-21-2012, 03:20 PM   #10
johndddd
My Ride: 02 m-3
Jake:
I just recieved my shrouds, the clips are at 9/3, can you remember what the location is on the BMW xenon projectors? If they don't line up I'm going to pass on changing out the shrouds.
Old 09-21-2012, 03:48 PM   #11
Solidjake
Zero. Leaks.
Solidjake's Avatar
Don't remember off the top of my head but look at my vid
Old 09-21-2012, 05:13 PM   #12
johndddd
My Ride: 02 m-3
[QUOTE=Solidjake;14751746]Don't remember off the top of my head but look at my vid
I watched the video several times and after pausing and getting a closer look it appears that the clips are at 9/3 after all Thanks.
