Old 09-16-2012, 02:03 PM   #1
Edgar3498
My Ride: 330CI
Head gasket
Hey guys Im having a problem with my 330ci 01 hope you guys can lend me a hand. Yesterday I finished installing my vf supercharge. Everything went well the car idles perfectly and feels great. The issue I'm having is that the valve cover is leaking so i change the gasket just to make sure but it keeps on leaking but only when on boost. It only leaks in one area or one bolt the one second from the passenger side from back to front. Please help what can i do
Edgar3498 is offline   Reply With Quote
Old 09-16-2012, 08:54 PM   #2
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Did you replace all of those rubber bolt seals when you did the valve cover gasket? You should.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 09-16-2012, 10:20 PM   #3
Edgar3498
My Ride: 330CI
No i didn't. Would that let oil leak.
Old 09-17-2012, 02:24 PM   #4
Edgar3498
My Ride: 330CI
Someone help
Old 09-17-2012, 02:40 PM   #5
SeanC
My Ride: 330i
See post #2.
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Alpine WhiteTanSand High Gloss e46 330i SlickTop/5MT - Sold
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
SeanC is offline   Reply With Quote
Old 09-17-2012, 03:02 PM   #6
bigjae1976
bigjae1976's Avatar
It could. Did you put RTV on the front half moon sections as well?
Old 09-17-2012, 04:12 PM   #7
sunnyjay
My Ride: 01 330i
I also wonder if supercharger is pressurizing the pcv system and cause the oil leak since he did mention it happens in boost only.
sunnyjay is offline   Reply With Quote
Old 09-17-2012, 04:39 PM   #8
Edgar3498
My Ride: 330CI
Yes i put RTV on the half moons. Could it be the pcv. Today I'm taking it apart again and cleaning the hell out of it to make sure its not crack or something. Any other suggestions.
Old 09-25-2012, 01:52 AM   #9
dirtbiker245
My Ride: 00 323ci, 02 325i
forced
Anytime you have forced induction on a car that was not originally designed for it, you increase your chances of random oil leaks.
I would definitely check the PCV system, they are known to have issues, I just changed my wifes cars whole system about a month ago.
Also, I had a crack in my valve cover on an old 323ci that I had. I don't know how the crack developed, but its possible. The joys of plastic valve covers.
dirtbiker245 is offline   Reply With Quote
Old 09-25-2012, 05:15 PM   #10
Jackcat559
My Ride: 2003 530
yeah that oil spearator (PCV) and hoses can fail and clogg. Change the all the gaskets and PCV system. Had a similar issue when I istalled mine.
Jackcat559 is offline   Reply With Quote
Old 09-25-2012, 05:35 PM   #11
04330ciZHP
My Ride: E46 E90
I would guess the supercharger kit didnt use the factory vent valve set up at least on the ess kit its a different pcv system, maybe a cracked valve cover, what brand gasket did you use? Ive also seen when the seal washers are reused the valve cover getting cracked.
Sent from my LG-P999 using Bimmer App
04330ciZHP is offline   Reply With Quote
Old 09-26-2012, 12:45 PM   #12
Edgar3498
My Ride: 330CI
Found the problem it was a hair line crack. I just bought a new one and clean the hell out if the old one and what you know a crack
