Old 09-16-2012, 10:26 PM   #1
330xIce
My Ride: 2005 330xi
Send a message via AIM to 330xIce
Lighting Noob Has a Question
Right now I'm running 8000k Khoalty HID's in my xenons and 2500k Nokya H3 Halogen bulbs in my projector fogs and Im starting to get sick of the setup. I want to go 6000k all around. Will I be able to put a H3 HID bulb in my projector fogs with no problem? Or would I need to buy a whole kit with ballasts and everything and do a retrofit.
Also, if i were to go with Halogen H3's such as these:
http://www.dhgate.com/h3-2-pcs-halog...faca0427d.html
would the color be an exact match to the 6000k HID's I will have in my xenons?
Thanks for the help. And I apologize in advance if this is a dumb question
Follow Me On Instagram: JamesMarshall_E46
///My Progress Thread - How To Set a Signature - Black Sedans FTMFW
-James-
330xIce is offline   Reply With Quote
Old 09-16-2012, 10:57 PM   #2
kaldE46
My Ride: 2001 325i
H3 is just the size of the bulb. You still need the balasts and what not. The 6ks will match if you get the kits from the same place, but there is a chance that they will be slightly different if your order them from different manufacturers.
kaldE46 is offline   Reply With Quote
Old 09-17-2012, 02:22 AM   #3
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
A H3 bulb is an incandescent bulb and therefore unable to properly match the 6000k temp color of a HID bulbs. You will be able to get close but as the bulb will have a coating on the outside of the bulb, as time goes by the color of the bulb will change drastically. You can however get a H3 HID kit for your fog lights. Just make sure that there is enough room in the housing.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 09-18-2012, 04:31 AM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
The H3 bulb should fit. I saw a DIY somewhere putting a hid bulb into those aftermarket projector housings. You will have to do some cutting to make it work right. I also advise running a wiring harness for the fogs
