Fan running after engine off 2000 323ci - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-16-2012, 09:44 PM   #1
Marlow.bailey
My Ride: Bmw 323ci
Hey guys
Fan won't shut off after I turn the engine off... Unplugged it to save the battery. Any clue what could cause. Hopefully it's and DIY project.
Thanks a lot
Marlow.bailey is offline   Reply With Quote
Old 09-16-2012, 11:32 PM   #2
MercForHire
My Ride: M235i 6MT
Replace fan
Old 09-16-2012, 11:35 PM   #3
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Your fan controller is bad. Controller comes with the fan. $140-160 online. $400 dealer.
BMWCaptain is offline   Reply With Quote
Old 09-16-2012, 11:36 PM   #4
Marlow.bailey
My Ride: Bmw 323ci
Thanx guys gonna order the fan.... Is it a DIY. Project or should I have someone replace it for me??
Old 09-17-2012, 12:03 AM   #5
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
the fans on mine run for a while after turning off the car...
/_________\
O==[][]==O
Old 09-17-2012, 12:05 AM   #6
Marlow.bailey
My Ride: Bmw 323ci
Mines won't cut off unless I unplug it
Old 09-17-2012, 12:42 AM   #7
BMWCaptain
If you drive a manual, its a 2 min job. If you have an automatic, much more complicated taking front bumper off. It all depends on how much of a DIYer you are.
Old 09-17-2012, 12:54 AM   #8
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
The engine fan I'm assuming?
Old 09-17-2012, 12:55 AM   #9
tock172
My Ride: '12 135i Dinan S2
+1, mine does too every now and then, usually either on hot days or after high performance driving. I thought it was supposed to do this?
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 09-17-2012, 10:41 AM   #10
WALDE_BORA
My Ride: 99' 323i, 99' JETTA
fan is held by 2 torx screws and 2 plastic 'nail-like' tabs. Pull the fan up carefully and re install back on the new fan. 10 minutes max.
If you keep on having the same problem after installing the fan, you should check the temp sensor on the rad hose.
Originally Posted by Alex323Ci View Post
I have a similar sound, but not a trrrr, it's a vrroom when I hit the accelerator pedal. it also stops when I take foot off pedal.
WALDE_BORA is offline   Reply With Quote
Old 09-17-2012, 10:44 AM   #11
MercForHire
My Ride: M235i 6MT
My fan stayed on after car's off once in last summer. Never happened again.
I figured it was a good thing, unless it never stops
Old 09-17-2012, 10:52 AM   #12
Rubenk
My Ride: M35A2
My manual trans 2000 323ci had the same thing happen. Fan controller was visibly exploded.
2 minute job to swap it out with a replacement.
Rubenk is offline   Reply With Quote
Old 09-17-2012, 01:01 PM   #13
Marlow.bailey
My Ride: Bmw 323ci
Thanx guys im going to replace sensor and fan just to be on the safe side got a great deal on a fan 110 I'll update the results on the AM..... My baby has 176k miles on here tryin to make it to 250 before i get a new one
Old 09-17-2012, 01:30 PM   #14
white46
My Ride: e46 323ci
Fan would be running for few minutes after shutting the car off on hot days. But when the fan control module goes bad, it will just run hours untill the battery goes out.
Since BMW don't sell the module seperately, you need to replace whole fan with module.
white46 is offline   Reply With Quote
Old 09-17-2012, 04:11 PM   #15
jdstrickland
My Ride: '94 325iC & '00 323i
Just because a fan remains on DOES NOT MEAN THERE IS A PROBLEM. The engine cooling fan, if electric, can run for several minutes after Engine Off. This is normal.
If the fan runs for 5 or 10 minutes, then I'd suggest that it is okay. If it runs until the battery is dead, then that can be a problem.
But, you did not say WHICH fan is running, so for anybody to tell you to go out and buy anything is perhaps poor advice.
Old 09-18-2012, 05:00 PM   #16
Marlow.bailey
My Ride: Bmw 323ci
Hey guys I replaced the sensor 1st becuz that was an easy fix. And to my surprise the fan is working properly. I let the car run idle for and 20 mins and fan can on for about 6 mins turn off... The temp gauge normal.. I did purchase the fan module so just for fun I'm going to replace it. I'm new to this DIY protects it will give me something to do
Old 09-18-2012, 05:24 PM   #17
330i ZHP
330i ZHP's Avatar
glad the fix was easy
/_________\
O==[][]==O
Old 09-18-2012, 05:33 PM   #18
BMWCaptain
Do you have a manual or automatic?
Share with us where you purchased your fan for $110.
Old 11-21-2012, 02:13 PM   #19
pugs2lenny
My Ride: 325i
My 325i is doing exactly the same ive just unplugged it from the top, i was reading into and from what i can gather there is high/low speed relay which controls the speed, my fan is constantly running at the high speed, so does this mean the high speed relay is stuck and if the case where is this relay?, cant find it, unless it is built into the fan and if this is the case would a simple change the fan rectify the fault?
pugs2lenny is offline   Reply With Quote
Old 11-21-2012, 02:18 PM   #20
Rubenk
My Ride: M35A2
It is built into the electric fan, you should see a box on the engine-side of the fan.
You most likely need to replace the entire thing, it is a 5 minute job to change it.
