Old 09-18-2012, 12:44 AM   #1
Snapasaurus
My Ride: 2005 325i SULEV
325i decent sounding exhaust without bribing the emissions guy.
Just as the title says; what's a decent sounding exhaust that will pass emissions? A friend of mine has headers on his 325i and it sounds great but won't pass emissions. What do you guys think would be a good setup?
Thanks, Geirsen.
Snapasaurus is offline   Reply With Quote
Old 09-18-2012, 01:05 AM   #2
EverydayGetaway
My Ride: 2003 330i ZHP
Golf tee mod.
EverydayGetaway is offline   Reply With Quote
Old 09-18-2012, 03:04 AM   #3
JS330
My Ride: '01 330Ci 3 Pedals
Originally Posted by EverydayGetaway View Post
Golf tee mod.
325i.....
Originally Posted by DeclanM3 View Post
I hope he isn't using Pirelli condoms..
JS330 is offline   Reply With Quote
Old 09-18-2012, 04:38 AM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Can we go back a bit? If it won't pass emissions, changing the exhaust won't help...unless in Canada, they fail it for loudness as part of the emissions test.
If your 'friend' removed the 02 sensors, then you either need to put them back, or figure out some electronic way to emulate the 02 sensor output so the car thinks it has them. If you have them and are still failing...the cat might be bad (or gone) and need to be replaced...and the warranty on cats is many years here...your 'friend' might be covered up there too.
When you replace one part of our car to get better something or other, you often then start a domino effect and can only get the car to work right when you've toppled all the dominos and made the car wrong...very wrong...then all will be right again!
See me in June!
dmax on Facebook
Mangofy your E46!
Old 09-18-2012, 12:20 PM   #5
robin325ci
My Ride: Helrot 325Ci
If you keep the stock headers then you shouldn't have a problem passing emissions no matter what exhaust you install since the cats are built into the stock headers.
Now regarding the sound, it's all up to you on how you define "decent". Search for clips on youtube and check out what you like best.
robin325ci is offline   Reply With Quote
Old 09-18-2012, 12:51 PM   #6
Snapasaurus
This is what I was leaning more towards, the only problem is that it's hard to find a decent quality sound clip.
Would just swapping the muffler give me sound I can hear in the cabin? Or will it be suppressed?
Old 09-18-2012, 01:01 PM   #7
robin325ci
I have a Supersprint muffler, which is known to be a quiet exhaust, and I can still hear it in the cabin.
Old 09-18-2012, 01:13 PM   #8
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Go to the official muffler delete page : http://forum.e46fanatics.com/showthr...muffler+delete
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 09-18-2012, 04:47 PM   #9
carcus
My Ride: 2006 BMW M5
I had a Dinan on my 325, sounded good. Mine was a M56 so it came with the 330 exhaust. I think the Dinan sounded much better. Try to pick up a used one like I did.
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
Old 09-18-2012, 04:51 PM   #10
jdstrickland
My Ride: '94 325iC & '00 323i
Thanks, Geirsen.
If the car has a working CAT, it will pass emissions no matter how good or bad it sounds. You are asking about modifications behind the CAT, and those modifications have no affect on smog. You could remove the exhaust from the CAT to the bumper and still pass smog. It would not be very pleasant for you or anybody within about a block, but the smog would be okay.
Your friend took his CATs off. There is no good reason to take the CATs off of a street car. A track car, maybe, but not a street car. So, unbolt the exhaust system from the CATs and replace it if you want, just leave the manifolds and CATs alone.
Old 09-18-2012, 05:43 PM   #11
FenderGuy05
My Ride: 2002 BMW 325i
Can you go straight pipes from the cat and pass emissions? Usually there's a visual aspect of the inspecition, at least in CA, right?
FenderGuy05 is offline   Reply With Quote
Old 09-18-2012, 05:50 PM   #12
ModBargains III
ModBargains III's Avatar
My Ride: E46
Technically you can go straight pipes if you want as long as you don't touch the OE Catalytic converters, so most catback systems will be 100% fine, you'll just have to leave your headers in place since that's where your cats are.
So honestly, If you want something conservative, I'd take a look at the first option. If you want something that sounds deeper and will give you more power since it's a cat back, then look at the second option:
Rogue Engineering IKON Exhaust BMW E46 3 Series
IKON Features
Just because the IKON exhaust system is easy on the wallet does not mean you are getting short changed. Features of the RE IKON E46 system include:
Only 21 pounds (replaces the 30 pound unit from the factory)
Full 304 Stainless Steel construction
Mandrel bent, not pinched, dual 57mm tubing (stock is dual 50mm), allowing for increased air flow yielding positive performance gains.
Mill-finished pipes and muffler, mirror polished dual 3" angle cut, double-walled, staggered tips.
Entire exhaust utilizes TIG welded construction
Deep tone (stock center resonator is retained)
Maintains BMW factory warranty
Rogue Engineering logo tastefully stamped in the body of the muffler
Adjustable mounting positions allow variable positioning with aftermarket bodywork
Can be clamped or welded (because factory exhaust must be cut, professional installation recommended)
aFe MACH Force XP Exhaust System BMW E46 325i/330i
Benefits
An increase of 13 HP and 15 ft. lbs of torque
304 stainless steel tips
2.25" tig-welded, mandrel bent, 409 stainless steel tubing
Utilizes all factory mounting locations
Weighs only 40 lbs.
Easy 1 hour installation process
Unlimited Mile Warranty
Increase in fuel economy
New deep throaty exhaust note
Increase exterior appearance
Straight bolt on installation
PM/Email or call for more info! - 714.582.3330 extension 8002, and ask for Jurrian!
Sean S. | Sean@ModBargains.com |(714) 582-3330 ext 8009
We Specialize In: BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts |
BMW Wheels In Stock | BMW Intake Experts
Hours
Check out our Blog for updates & discounts!
ModBargains III is offline   Reply With Quote
Old 09-18-2012, 05:58 PM   #13
Snapasaurus
Is a supersprint quieter than stock?
Im honestly looking for a cheap way to get a louder sound that isn't ricey. If I can get a deeper tone, that would be great too. Can I achiever this just by replacing the muffler? Or will I have to go further back?
Old 09-18-2012, 06:24 PM   #14
HiHoBrian
My Ride: 05 M3
Some of those systems posted above look great. Other popular brands you can search are Remus,and Billy Boat. The Remus is usually a deeper tone muffler.
Edit: Also a muffler alone will likely get the results you want. Replacing the pipes further back typically eliminate the resonator and that is the part that keeps the rasp (ryce) in check. Leave those stock,you can always swap them out later if you want.
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 09-18-2012, 06:27 PM   #15
iceberq
My Ride: 02 LSB M3
Eisenmann race cat-back was good on my 325ci. This was their race muffler and mid-pipes:
iceberq is offline   Reply With Quote
Old 09-19-2012, 09:16 AM   #16
2000_328CI
2000_328CI's Avatar
http://www.youtube.com/watch?feature...&v=ofYhRq0T3eI
Old 09-19-2012, 06:20 PM   #17
Snapasaurus
This sounds nice, Im just worried it'll be too loud.
Old 09-20-2012, 04:42 AM   #18
robin325ci
Supersprint is louder and sounds deeper than stock. It's got a nice, deep, German accent. Definitely not ricey. If you find it too quiet for your taste, you can always remove one or both resonators.
Old 09-28-2012, 11:21 AM   #19
Snapasaurus
I'm thinking of going with a muffler delete and just keeping the rest stock for the time being. Just so I don't get screwed, what would be a reasonable price to have this done?
Old 09-28-2012, 11:38 AM   #20
jdstrickland
The emissions test in California only looks at the CATs and the emissions. The test does not care what comes after the CATs, and there could be nothing and the car would still pass emissions. The noise makes problems, but emissions will be okay. The Smog Police do not look for a muffler, they only look for the CATs. Well, they also look for the necessary sensors and such, but they do not look for a muffler. The cops don't like the muffler to go away because this usually causes the noise to be above some acceptable limit.
