#21 |
I,ve done the carpenter thing before but just fancied a change
With your tablet you can do even more android has mush more for car compareD to blackberry |
#22 |
Hi guys, I'm new here and am about to pick up a 330cd on Sunday to replace my beloved Subaru.
I've been reading up on threads like this with interest but there's something about the http://www.bmdroid.co.nz/ build that I just don't get: Why use the Grom interface when you could just use a cable to connect the tablet's 3.5mm output socket to a head unit's RCA inputs? Then you just use the channel on the stereo that's for the RCA input, rather than this method involving the CD Changer channel. It's possible I'm totally missing something here, hence my asking! I'm planning to install one myself with such a cable. I'm debating a signal booster between the tablet and head unit, but not made my mind up yet. For my intended install, I'm toying with relocating the head unit's fascia panel to the glovebox or somewhere else to retain some of the head unit's functions. I'll install a 4G wifi modem in the car to provide both the tablet and passengers with wifi access and will hook it up with a USB socket around the ashtray area. The socket will be cabled to the tablet's micro USB. This will allow me to easily hook up a laptop if I want to move any media on or off the tablet's storage and it means I can let the battery charge down a bit sometimes, which is essential for its health._nr_ |
#23 | |
Now, one thing I really don't understand with this install is why does he use the GROM adapter? Why would you not just use a 3.5mm to RCA connector and play the tablet through the head unit that way? |
#24 |
Wouldn't it be easier to mount the radio in the glove box rather than taking it apart??
#25 |
I'm doing this same thing with a Nexus 7 and my Mazda Rx-7
Still in the design and build process... ![]()
#26 |
The post I wrote last night never appeared so I wrote another. Now they're both there ! Wah!
#27 |
bump
#28 | |
You might find that BMW headunit does not support RCA or AUX input (depending on the year of the manufacture). The only E46 bmw headunits that could do AUX input are CD46 models build after 2003 if i am not mistaken. I didn't want to go through the pain of spending time and money and installing an aftermarket headunit and loose the volume control on the multifunction steering wheel, that is why i decided to put it the sound through the original bmw headunit and to do that you need GROM audio box or similar interface that emulates CD changer. Hope it explains it and hope i provided some good info to all of you who considered doing the same thing in their cars and your projects are going well. Cheers, BMDROID_nr_ |
#29 |
Hi, residential over-thinker here. So where or what step allows us to get the steering wheel control function? I bought the car with an after market HU and the steering controls don't work. I guess it is entirely possible I have the module back there and the HU doesn't support it. Is there any way I could verify short of pulling it down?
and I see the GROM wire you used. What's the difference between that and this setup that mounts behind the radio? http://www.gromaudio.com/store/usb_a...sb2p-bmws.html It seems like this offers a lot of redundant features that we'd be getting with the tablet install. which is apparently different from this module that mounts in the trunk which apparently I need if I have DSP. I know it's labeled in the trunk but I'm away from the car right now and will be for the next 2 weeks. I know that i have an e46 330 with premium package and H&K set up http://www.gromaudio.com/store/usb_a...sb2p-bmwt.html also what if we wanted to add bluetooth to the tablet set up or a voice recognition device granted our tablet supported that? How would I go about accomplishing this I know we're playing sound through the CD player mode of the stock radio but in my experience auxiliary port audio has been significantly lesser quality. The GROM setup boasts of 18 bit sound quality which apparently is better than CD player. I don't know enough to call b.s on that or not. I'm definitely going this route because DYNAVIN is way over priced for getting a software that's as out of date as it is. One thing I am hesitant about is downgrading in sound quality going from my Alpine IDA-X100. It'd be nice to have steering wheel functions and bluetooth setup though._nr_ |
#30 | |||||
Also if you are saying that you have HK in your car - you should not be worried about the sound quality as HK sounds really good. Moreover with tablet setup you will not be using your headunit much at all because it will be hidden behind the tablet, although it depends on how you will set it up. Quote:
Use your vehicle's VIN to find out if you have DSP or not, although generally if there is an aftermarket HU - i doubt that you have DSP. Quote:
Good luck. |
