Old 09-11-2012, 10:48 PM   #1
FrancoM
My Ride: 2005 BMW 330Ci
E46 Idle Whistle... Can't find the problem :(
I've changed :
Water pump
Idler Pully
Tensioner Pulley
Thermostat
Spark Plugs
All belts
I still have the sound. I really don't know what it is. It goes away when i apply throttle.
It whistles only when idle. It's really annoying and very embarrassing driving a BMW sounding like this at a drive thru.
Please someone help me out :
Video of the sound:
FrancoM is offline   Reply With Quote
Old 09-11-2012, 10:57 PM   #2
shwagon
My Ride: 325it 5-speed
Possibly a torn air boot, also you might want to clean your throttle body along with your IAC valve. There could be just enough carbon build up to cause a whistle.
Originally Posted by Reedo302 View Post
What an unending cavalcade of rampant virgin Mom's-basement-dwelling douchebaggery... Wow.
My Gun Builds: AR-15, GSG-522-SD, Saiga 308
shwagon is offline   Reply With Quote
Old 09-11-2012, 11:00 PM   #3
FrancoM
what air boot are we talking about here? Is there a DIY on any of these?
Old 09-11-2012, 11:28 PM   #4
FenderGuy05
My Ride: 2002 BMW 325i
The rubber portion that runs from the air box to the throttle body. Two sections. I think I'm having a whistle under acceleration, so i'll be changing mine out next round of DIYs.
You just need to undo some hose clamps more or less. If you look up clean ICV DIY you can see the process.
FenderGuy05 is offline   Reply With Quote
Old 09-12-2012, 12:18 AM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
See first link below in my signature.
Old 09-12-2012, 12:19 AM   #6
deadwood83
My Ride: has an iron lung
Send a message via MSN to deadwood83
That's your secret supercharger.
AA Stg2+ 325xiA? Are you stupid? Maybe a little.
I can program cars fo' freeee near Salt Lake City. PM for details.
deadwood83 is offline   Reply With Quote
Old 10-04-2012, 03:30 PM   #7
FrancoM
i cleaned the icv and the throttle body... it doesnt make sense... my boots aren't torn either..
