E46 Convertible
The E46 vert forum. Talk about dropping your E46 top here. |
#1 |
Anyone know how to fill up the convertible pump with hydraulic oil?
Any pictures would be great if anyone has done this before. Mine is running low on my 325Ci convertible and I have to add some. I know the pump is in the trunk area on the drivers side but I don't know where to fill.
Thanks for helping out. _______________ |
#2 |
send me your email and ill send you the procedure in jpgs
#3 |
pm sent
#4 |
Thanks wtm2w. Awesome pictures
#5 |
I never heard of this one. How do you know it needs fluid? Where is it checked? Thanks!
#6 |
Where is this container? What fluid does it take?
![]() Bone stock, style 68s FTW! |
#7 |
i think you should post the pictures, and the mods can make it a sticky
![]() Carbon Black Metallic SMG II Verttttt VCSL Front Bumper VCSL 1 Piece Splitter VIS GTR Hood 6K Angel Eyes VMR VB3 19's KW V2 coilovers |
#8 |
My Ride: TiAg e46 Vert
post the pics!
#10 |
Thanks!
#11 |
E-46 Cabrio, Do you know if they ever changed anything through the production year ending 2006, with regard to the manual? It appears it was produced in 2000. Thank you for posting it.
Rob |
#12 |
anyone know how full the clear container should be? My container is more than 3/4 full I am not sure how to fill it.
#13 |
I don't think so, all the hydraulic pumps are the same 318CI-M3, 2000-2006.
#14 |
Only fill the container when the top is open.
#15 |
My mechanic told me that unlike other fluids in the car, this system should never 'run low'. If you need fluid there is probably a leak somewhere...which will be very expensive to repair.
#16 |
My Ride: Velvy B.
This is exactly what I heard too.
| There is no replacement for Displacement | Go Big or Go Home | ![]() |
#17 |
My Ride: 2004 330ci Vert
How about the hydraulic oil type? Does it need to be OEM from dealership, or can regular hdyraulic oil be used?
#18 |
#19 |
#20 |
Where would those seals be? I bought my car with troubles to open, very weak. I checked the fluid and it had almost a quarter of a cup too much. I took the fluid out but a little too late, the damage is done. Is there a solution?
