Go Back   E46Fanatics > E46 BMW > Regional Forums > Southwest
Southwest
AZ NM NV OK TX UT
Old 09-19-2012, 11:04 AM   #1
Montreal e36
My Ride: e30 e36 e46
DPE Aristo 19x8.5/9.5
Link to the rest of the album
https://picasaweb.google.com/1105001...Mub5cvIg92oAQ#
Up for sale are my DPE Artistos which are extremely rare. They have been Professionally refinished due to two of the lips being bent, with this said 2 lips are NOT perfect but have cosmetic damage which is why I went with having them done fully Satin black (semi gloss). The fasteners were also painted the same color as well as the center caps. These are true 3 piece wheels and are not in show quality, they will look fine on a street car and the blemishes will go unnoticed. Now on to the specs.
19x8.5 et ~35
19x9.5 et ~35
5x120 bolt pattern
72.6 hub bore
Made for NON-//M e46's although you can run them on a e46 //M if you run a 20mm spacer in the rear. these can also work on many other models with spacers or hub adapters, considering that the lips had been repaired I will let these go for $750 local!!!
Email me for inquiries to Montreale36@gmail.com
and check my I-trader rating on bfc
http://forums.bimmerforums.com/forum...r.php?u=116023
Montreal e36 is offline   Reply With Quote
Old 09-25-2012, 03:37 PM   #2
Montreal e36
bump
Old 10-02-2012, 07:33 PM   #3
coors2003
My Ride: 00 323CI
sent you an e-mail
coors2003 is offline   Reply With Quote
Old 10-07-2012, 06:14 PM   #4
Montreal e36
Emailed back, Price drop $750 local
