Sponsored by BAVSOUND
Old 06-27-2003, 06:49 PM   #1
clarkrw3
clarkrw3's Avatar
My Ride: 2003 M3
Send a message via AIM to clarkrw3
Question DEI 504D shock sensor where to put it
Ok...I bought a DEI 504D shock sensor rather then the 504M I thought only the wiring was different but I am having a hard time figuring out where to put it in the headliner. It is about 3/4in. tall but looks exactly like the ones I have seen pics of in the write ups. However, there is only a 1/4 to1/2in gap between the headliner and the metal cover for the sunroof so where do you all put it and does anyone have a picture of where they placed it before the motion sensor was put back up in the roof? Also mine doesn't have the fuse in line with the shock sensor, can I do without the extra fuse? This is on a 323i.
clarkrw3 is offline   Reply With Quote
Old 06-27-2003, 09:07 PM   #2
guest1016
fanatical
My Ride: .
Send a message via AIM to guest1016
um, the proper place is behind the glove-box. you can access the wiring here as well..
guest1016 is offline   Reply With Quote
Old 06-27-2003, 09:21 PM   #3
Malladawg
Beware of pwner
Malladawg's Avatar
My Ride: 2000 323I OrientBlau
Send a message via AIM to Malladawg Send a message via MSN to Malladawg Send a message via Yahoo to Malladawg
I tried using the 504D, and when I hooked it up, I no longer had an audible confirmation that the alarm was armed. I hope you have better luck with it.
Malladawg is offline   Reply With Quote
Old 06-27-2003, 09:47 PM   #4
E46ElitistPrick
Never Follow.
My Ride: 2006 Honda Ridgeline
I did mine in the headliner... works fine
Patrick
E46ElitistPrick is offline   Reply With Quote
Old 06-27-2003, 09:51 PM   #5
clarkrw3
clarkrw3's Avatar
My Ride: 2003 M3
what wires did you use behind the glove box...do you know of any DIY write ups on the glove box location?
Old 06-27-2003, 10:26 PM   #6
starscream
Broke as hell
My Ride: '01 330xi
http://forum.e46fanatics.com/showthr...threadid=86170
That is what I am doing with mine on Monday Today I installed the OEM Xenons and the Xenon Look Fogs
STARSCREAM
BEFORE ACCIDENT '01 330xi
AFTER ACCIDENT '07 Infiniti G35x
starscream is offline   Reply With Quote
Old 07-19-2003, 02:25 AM   #7
devGOD
devGOD
My Ride: AA S/C 2000 323i
Send a message via AIM to devGOD Send a message via Yahoo to devGOD
why would you put the DEI in the headliner, wouldn't heavy rain beating on the roof set off the alarm if the DEI is up there?
Xbox360: devGOD
devGOD is offline   Reply With Quote
Old 07-19-2003, 08:28 AM   #8
guest1016
fanatical
My Ride: .
i have the 504D mounted behind my glove-box. works excellent. If your not getting audible confirmation, something is not right with the unit. the 504M and D models are the same, just have different plugs on them which you cut off anyway....just locate you 12v source, ground it, and find your neg. out hood pin switch wire. they are all in one location bsaically. I posted pics on here some time ago, don't know if they are still around however...
Old 07-19-2003, 08:30 AM   #9
-=Stu=-
UK Member
My Ride: .
Is it possible to add the additional shock sensor to a Convertible ?
Thanks,
Stbuart.
-=Stu=- is offline   Reply With Quote
Old 07-19-2003, 11:10 AM   #10
devGOD
devGOD
so whats a better place to put the DEI headliner or behind glove compartment?
Xbox360: devGOD
Old 07-19-2003, 01:54 PM   #11
E46mtech
MMM Power
My Ride: 2003.5 M3 & Cadi SRX
I say behine the glove box...
it will work all the way around for impact
E46mtech is offline   Reply With Quote
