Old 09-20-2012, 02:48 AM   #21
cityjohn
My Ride: 2001 M3
OK great will let you know
cityjohn is offline   Reply With Quote
Old 09-20-2012, 11:11 PM   #22
serdar255
My Ride: '01 325ci / '90 325i
Originally Posted by e46dude93 View Post
19 year old here. not molesting my car like the other ricecakes in my college parking lot. maintenance is #1 in my mind! and a thanks to mango and dmax and everyone else steering me in the right direction. but even i can appreciate someone like mango putting this info out there. thanks for the write up!
I can appreciate that, i'm 15 myself.
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 09-20-2012, 11:15 PM   #23
325inthe510
My Ride: 152ci of madness
Did you seriously join this forum as a 13 year old? And you can't even drive wtf are you doing here
325inthe510 is offline   Reply With Quote
Old 09-21-2012, 12:33 AM   #24
serdar255
Yes, 13, had originally joined for info on replacing a CPS 2 years later i'm here.
I'm enjoying my e46 just like everyone else, learning, maintaining, cleanly modding, and soon will be manufacturing parts. (quite excited about that, just tested my homemade vacuum forming machine and will be making parts out of petg and carbon fiber) click the sig link for more info.
Old 09-21-2012, 07:48 AM   #25
trizzuth
My Ride: 228k, 16yr old B3AST
I was unable to remove the position sensor as it has a 5-sided security torx bit. All my bits are 6-sided. I doubt anything is wrong with it anyway I just wanted to have a peak inside.
Come on now!!!!! PEEK. I expect more from you.
Edit: I've read about this so-called strange area of the RPM band on 330's. However, on my 2001, I do not have any such lag or jerk or whatever it is anywhere across the RPM band. Just a F'n annoying wa wa wa wa wa noise that I can't diagnose!
trizzuth is offline   Reply With Quote
Old 09-21-2012, 09:18 AM   #26
GSherbs
My Ride: 2002 330 xi
Thanks five and serdar and whoever else. Yeah for sure I'll let you guys know if i track it down. it's just as you described, nick. i can prevent the kick from happening if i throttle slowly and gradually. but if i try to take off semi-aggressively, no bueno.
I've been following some of these threads despite not experiencing the issue myself.
I'm just wondering - do you still get the same behavior if DSC is disabled?
GSherbs is offline   Reply With Quote
Old 09-21-2012, 10:33 AM   #27
My Ride: Lexus
Since you're a nice guy, I'll answer.
I've answered/discussed this numerous times, yes. it has absolutely nothing to do with DSC and is nowhere near DSC threshold. Talking normal take-offs getting groceries, going to DMAX's comedy gigs, etc. Normal driving.
I'm not worried or complaining or giving it too much thought. It's not a big deal, just slightly annoying to deal with.
Old 09-21-2012, 12:49 PM   #28
johnrando
My Ride: '06 330 CIC ZHP
This is interesting info, thanks for posting. Just so I'm clear... you weren't able to remove the "switch", so you're not sure if taking it out will change the kickdown? Cityjohn, if you buy the pedal, I'd be real curious to hear what happens if you remove that "switch".
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 09-21-2012, 12:58 PM   #29
My Ride: Lexus
Huh? No. I did remove the switch. I drive a manual. No kickdown for me. That's why I removed the switch cause I don't need it.
My 2002 manual pedal is for sale. i'll throw in the switch if someone needs it. if not, i'll chuck it in the ocean or feed it to a squirrel.
switch is just a clicker. does nothing but makes noise
Old 09-21-2012, 04:20 PM   #30
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Crazy thought...which I'm making up for you...see if you can turn it into a non-crazy thought...and don't yell at me!
02 sensors when bad seem to trigger a signal with a straight climb up, as opposed to a slanted signal increase...I think that's right...maybe the opposite.
I'd guess 02 sensors might trigger a jump, a kick forward from more gas being called for all of a sudden...
Something like that. I'm sure you have newish 02 sensors, but maybe other sensors are giving a dicey signal that's triggering ecu to give it a kick of gas. When AC comes on...I know the idle increases...all this happening without AC?
If that doesn't work, just replace your cooling system to relax you and channel your car's ailments. Have you been doing your readings of Bentley everyday?
Facebook.com/DMAXstandup
Mangofy your E46!
Old 09-21-2012, 04:28 PM   #31
My Ride: Lexus
ac doesn't play a role. i'm going to unplug my maf and try again (i thought i did this before but not 100% sure)
like i said i have a new throttle body coming. im also thinking about the golf-t mod... anyone know if the flap in the exhaust is in any way wired to the DME? I highly doubt the flap opening or closing would require timing or fuel changes.
whatever change is happening, it's happening at around 2,500 rpms upon increasing throttle input (will not happen if throttle is steady)
Old 09-21-2012, 05:08 PM   #32
lcoleman
My Ride: '79 Massey Ferguson
Have you considered some problem/stickiness in the actuation of the VANOS? I would also inspect engine/trans mounts, guibo, etc.
I do not think fuel metering (ie. bad O2 as dmax suggested) would create a jerk--more likely a change in timing.
Old 09-21-2012, 05:23 PM   #33
My Ride: Lexus
I don't want this thread to turn into a troubleshooting thread. This has been hashed out/discussed numerous times already. The end result is always the same.
No matter what you say or can think of, it's been done. Sometimes twice. The entire car is pretty much brand new front to back. you guys know me!
This is something I'm privately troubleshooting and investigating. I highly highly HIGHLY doubt anyone can come up with a workable solution. This is just something I have to handle on my own (which I am)
I appreciate the help though. I can manage.
I'll handle it on my own unless I need specific specific help--detailed knowledge on something extremely specific.
Old 09-21-2012, 05:25 PM   #34
My Ride: Lexus
Also there's a handful of people out there experiencing the same thing on their manual 330s. So obviously if I find a solution, I'll let the community know.
Old 09-21-2012, 05:45 PM   #35
patdown
My Ride: 2005 BMW 330Ci
I also have a sudden "kick" in acceleration around 3100-3300 RPM. I didn't notice this until I got in on the AA group buy last year. It's almost like the car is coming onto the cam or the secondaries kick in on a carb'd engine. I'm not really complaining about it, just curious.
I asked AA about this issue but never got a response.
Pat
2005 330Ci ZHP 6MT
AA Tune, domestically engineered CAI w/aFe Pro S, UUC TSE3,
Cooling Sys ovhl with Stewart WP, BMW M3 Front Strut Brace,
Koni FSD struts/shocks with original springs,
Cryo-Stop Rotors, Akebono Euro Ceramic pads, SS Brake/Clutch lines, CDV Delete,
Mason Engineering clutch pedal, Umnitza Predator Orion AE's, smoked corners and sides,
VMR V710 18" Staggered w/Hankook Ventus V12 235's/FR and 265's/RR
patdown is offline   Reply With Quote
Old 09-21-2012, 05:48 PM   #36
My Ride: Lexus
Was this as a result of AA? (tune i'm assuming) or did it do it before?
This may not be the same problem as i am talking about.
Old 09-21-2012, 07:50 PM   #37
johnrando
OK, thanks for clarifying. I misunderstood.
Southern California
Old 09-21-2012, 09:22 PM   #38
My Ride: Lexus
No problem. Part of the reason I made this thread is because over the years I feel there was a misconception that there's an actual switch that electronically activates kickdown. people go NOOO DONT USE A MANUAL PEDAL OR ELSE U WONT DOWNSHIFTING!
Wrong! it's just a clicker. we all know that the kickdown "switch" isn't a switch at all. but just a clicker. like something you train dogs with.
Old 09-22-2012, 12:23 AM   #39
TerraPhantm
My Ride: M3 & ZHP
Mango, does the throttle response feel different otherwise? Every auto BMW I've driven revs much more freely in neutral than the manual equivalents. I don't really understand why since the DME software is the same. I thought maybe the potentiometers in the pedal might be mapped differently
Old 09-22-2012, 03:04 AM   #40
My Ride: Lexus
you bring up a valid point. it feels exact the same as before.. i think these "potentiometers" (I put that in quotes cause I honestly don't know how they work or are set up) are detachable by two torx screws. ill try to check it out. maybe they can be swapped?
now you've got me worried... car seems fine though!
