Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 09-19-2010, 12:21 PM   #1
shady1013
My Ride: 99 323I BMW
99 323I running rough at idle and stalls
Ok i am having issues with my e46 (99 323I) at start up idle it is really rough codes read misfire and i replaced the spark plugs, fuel filter and i still dont know what to do. the lights on my dash show check engine, an orange triangle with an ! and a circle around it, my break is on with ABS. I am lost on my next move it makes a clicking sound by the engine every once in a while and exhaust sputers every few seconds. i can answer any other questions just ask, the next thing i was looking at was cleaing my idle control valve but i wasnt sure if that would fix it.
shady1013 is offline   Reply With Quote
Old 09-19-2010, 12:26 PM   #2
ALPIN3
My Ride: E46 M3 & E46 323i
Fuel pump perhaps. Common issue.
ALPIN3 is offline   Reply With Quote
Old 09-19-2010, 03:15 PM   #3
shady1013
if it is the pump any way i can check it? and if i was to replace is it just the pump or do i need the whole assembly?
Old 09-19-2010, 03:26 PM   #4
mack89
My Ride: '02 TIAG 330i 5spd
CEL and DSC+ABS+brake, huh?
Well DSC+ABS+brake light is not related to engine system. You have defective speed wheel sensors.
For rough idle & stall issue, I'd check MAF sensor and vacuum leak. Vacuum leak can cause rough idle, but it has to be huge leak to stall the engine. So my money's on MAF sensor.
And yeap, misfire codes are most likely caused by bad MAF sensor, less likely caused by spark plugs/ignition coils.
Here's the quick diagnosis
a) Start the car in the morning, check the RPM. Needle should go up to 1200-1500rpm right after the ignition and 7-800rpm on idle.
If the engine starts up so weakly and rpm needle won't go over 1k then makes rough idle in 2 minutes, most definitely MAF sensor.
OEM MAF sensor goes around $350-400, freaking expensive
But you have alternative option. Hyundai Sonata 2.5L model uses same MAF sensor, but much cheaper. $150ish. Check this thread for more info
http://forum.e46fanatics.com/showthr...hlight=hyundai
And fuel pump won't give you SES code. You might notice symptoms when the fuel pump is failing, but it's hard to notice just like power steering pump. They just tend to fail without warning sign, weird symptoms, etc.
mack89 is offline   Reply With Quote
Old 09-19-2010, 06:01 PM   #5
ALPIN3
That's not entirely true. Just from personal experience, when my fuel pump died, the car went into limp mode, and threw a misfire CEL code as well. If the engine is starved of fuel, a code will pop up.
Old 09-19-2010, 06:26 PM   #6
shady1013
well i replaced the fuel pump relay and you can hear the pump make noise when you turn on the car.
Old 09-19-2010, 08:24 PM   #7
johnnysacco
My Ride: 2000 323i
I had a similar problem in my 323i. Turned out to be a bad ignition coil.
johnnysacco is offline   Reply With Quote
Old 09-19-2010, 09:01 PM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Clean your MAF first.
Old 09-19-2010, 09:04 PM   #9
crazyafghanguy
My Ride: E46 M3
check coils
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
Street Edge Coilovers
ZCP Brake Upgrade
LED Tail Lights
crazyafghanguy is offline   Reply With Quote
Old 09-19-2010, 09:13 PM   #10
ace_of_hearts
My Ride: M3
Originally Posted by crazyafghanguy View Post
check coils
+1
Misfire codes are usually caused by either coils or spark plugs.
Since you haven't mentioned changing the coils.
Here is a DIY to check coils:
ace_of_hearts is offline   Reply With Quote
Old 09-24-2010, 04:50 PM   #11
shady1013
Ok after extensive work cleaning and trial and error i found a hole in my Rubber Boot the connects my MAF to something well it cost me 62$ at the dealership. but solved all my issues thanks for the help and hope this helps anyone having the same issues.
Old 09-24-2010, 04:51 PM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
Buy it online...
Old 09-24-2010, 05:29 PM   #13
Spartan E46
My Ride: 2000 323i
Had the same set of issues. Check the condition of your battery and/or charging systems. A weak battery / insufficient power can wreak havoc on the electronics in your vehicle. Replacing my battery took care of all the issues I was having.
Nevermind - just saw you had the problem fixed. I usually try to rule out the battery whenever I get multiple lights/sets of codes.
Spartan E46 is offline   Reply With Quote
Old 04-23-2011, 04:25 AM   #14
mikechen1212
My Ride: US
Hey, was your problem something like this?
I'm having a misfiring problem with a tapping noise. Thanks!
mikechen1212 is offline   Reply With Quote
Old 02-05-2014, 09:19 PM   #15
racer55000
My Ride: m3
please let me know what you determined the problem was?
racer55000 is offline   Reply With Quote
