///M3 Forum
Old 09-19-2012, 08:42 PM   #1
Cayne23
My Ride: 2002 m3 convertible
rattle sound under car
I think im hearing a loose heat shield under my car when i carry out my gears. Starts at about 4000rpms. Is this common?
Cayne23 is online now   Reply With Quote
Old 09-20-2012, 01:48 AM   #2
TArse
My Ride: 03 330xi, 87 325is
I got the a rattle (i have full exhaust ) in the lower rpm range when the exhaust note is at its lowest.
I think it's a heat shield but I can't find it.
TArse is offline   Reply With Quote
Old 09-20-2012, 09:51 AM   #3
DSilk56
My Ride: M-3 Convertible
It might be the exhaust vibrating against the shield (or something else). Check the exhaust mounts, and also check the engine mounts. As they wear, the engine drops slightly. Since the engine moves on its mounts when under load, that motion might be enough to result in contact between the exhaust and the shield.
DSilk56 is offline   Reply With Quote
Old 09-20-2012, 10:26 PM   #4
BWOODM3
My Ride: 2002 M3 convertible
Yeah, mine does this when im coasting or accelerating at a lot speed. Never found the problem.
BWOODM3 is offline   Reply With Quote
