///M3 Forum
Old 09-20-2012, 08:05 PM   #1
Cayne23
My Ride: 2002 m3 convertible
differential looks wet
so I noticed the other day some wet spots on the ground where I park. I looked under my car and it looks like the differential, I think, is wet. could it b just a gasket or just loose? how easy to replace gasket or tighten. how much for gasket and new fluid?
Cayne23 is offline   Reply With Quote
Old 09-20-2012, 08:46 PM   #2
aznniche
My Ride: E36
all i've seen diff's look wet, as long as its not pouring out, i wouldn't worry about it. there are diy's out there that replaces the seal if you want to do it...do a search
aznniche is offline   Reply With Quote
Old 09-24-2012, 09:09 AM   #3
dillard
My Ride: 2004 M3 Cabrio
I have the same problem. Very small leak. From my searches, it's the pinion seal. I was quoted $500 to replace. The DIY says it's a PITA as you have to use a seal press. On my to do list.
Proud owner of '04 M3 Convertible:
dillard is offline   Reply With Quote
Old 10-01-2012, 06:26 AM   #4
Beamer Creamer
My Ride: 2005 bmw m3
If its dripping fix it. Seals dont usually press out. Pry out then use seal driver and floor jack under work bench if u gotta. Tightening means should change gasket anyways
Beamer Creamer is offline   Reply With Quote
Old 10-01-2012, 07:31 AM   #5
greenhobby
My Ride: 2002 e46 M3
Just had my seal replace this summer. If the leak is on the same side as the exhaust, it's a PITA. I had mine done at Turner Motorsport. Great work while you wait.
greenhobby is offline   Reply With Quote
