///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 09-20-2012, 09:10 PM   #1
alexzone007
My Ride: m3 e46
e46 m3 EML LIGHT PROBLEM
Hi people i need help here my eml light is turning on when i am driving the car and after the lights turns on the car goes like dead no aceleration on the pedal everytime the cars do this to me thats is everytime now i turn off the car and start the car again and the light turns off and car runs ok after time the car turn the eml light again and goes on limp mode i need help i heard could be the (pedal acelerator sensor) or something on the engine asociated with it thanks for the help
alexzone007 is offline   Reply With Quote
Old 09-20-2012, 09:30 PM   #2
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
It's probably one of the two main engine sensors. But it could be coils, cats, or several other things. You need to get the codes read in order to have any idea of what really wrong with the car. At this point it's all pure guess work.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 09-20-2012, 11:17 PM   #3
$ilent ///M
My Ride: 03.5 M3 smg lsb
normally eml light is related to throttle position inplausibilty. But like turbo_f22_pilot said get codes read first. most easiest sensor to get to is the one you have to disconnect to change the oil filter.
$ilent ///M is offline   Reply With Quote
Old 09-20-2012, 11:25 PM   #4
rcsummers
My Ride: M3
had the same problem. My rear throttle position sensor and throttle actuator went bad.
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 09-21-2012, 01:40 AM   #5
alexzone007
My Ride: m3 e46
thanks guys for the help i am reading my codes this week
Old 09-21-2012, 03:31 AM   #6
turbo_f22_pilot
Use a reader design specifically for BMW's. Not one that generates generic OBDII codes. If you are in the P.R., there is a fanatic with a GT1/DIS/INPA laptop that might be able to assist you. Ask in your regional section and see if they respond.
Joy is future proof
CAR:
MODS:
BMWCCA NCC
Old 09-21-2012, 04:06 PM   #7
LestA///M3
My Ride: BMW M3 2003
Send a message via MSN to LestA///M3
Just wondering would this reader also work? It's cheap
"Autel MaxiScan MS300 CAN Diagnostic Scan Tool for OBDII Vehicles"
///M3
LestA///M3 is offline   Reply With Quote
Old 09-22-2012, 02:52 AM   #8
alexzone007
My Ride: m3 e46
bmw technitian only for sure thanks
Old 09-22-2012, 04:57 PM   #9
vonbimmer
My Ride: 01' E46 M3
I just had this issue on my M, I replaced the front sensor since its cheaper than an hour of diagnostic labor, but no luck. That said I took it to the dealer and with the über computer they have they could test both and the actuator at the same time. The result, diagnosis bad actuator. Saved me from taking it all apart for the Tps under the manifold or guessing about the pedal. Diagnostic cost $120, certainly worth it if you trust your dealer since it could be any of four parts. Just my experience and $0.02.
vonbimmer is offline   Reply With Quote
