Old 09-21-2012, 08:47 AM   #1
matthatchett
My Ride: 2006 BMW 325i
Maintenance Schedule
I recently just purchased a 2006 BMW 325i with 65k miles. It didn't come with any service records or anything so I'm kind of in the dark on what has/hasn't been recently serviced. I've done a little research on the old school bmw maintenance schedule and this is what I have come up with. I tried to go with the minimum requirements. Please let me know if you have any suggestions or if I am missing anything!
Oil- 5k
Spark Plugs- 15k
Air Filter- 15k
Interior Air Filter- 30k
Valve Adjustment- 30k
Power Steering Fluid- 30k
Automatic Tran Fluid/Filter- 30k
Differential- 30k
Timing Belt- 50k
Tensioner Pulley- 50k
Front Cam Seal- 50k
Fuel Filter- 60k
Water Pump- 60k
Engine Drive Belt- 60k
Thermostat- 60k
Thermostat Housing- 60k
Radiator- 90k
Expansion Tank- 90k
Fan/Fan Clutch- 90k
Water/Fuel Hoses- 100k
Coolant Hoses- 100k
Brake Fluid- 1yr
Coolant- 2yr
matthatchett is offline   Reply With Quote
