///M3 Forum
Old 09-22-2012, 03:32 PM   #1
vmals89
My Ride: e46 m3
Subframe Bushings help.
Im pretty sure the bushings need to be replaced because i hear the clunk noise when shifting at low speeds. I know usually with this the subframe causes cracks, but i dont hear any of the noises associated with a crack. could it be i only need the bushings and not welding, or does bad bushings always mean there is a crack?
Vas
vmals89 is offline   Reply With Quote
Old 09-22-2012, 04:12 PM   #2
illestminimike
My Ride: Project Drama
You are positive that clinking is from the subframe? Sounds like the famous M clunk from what you said.
Old 09-22-2012, 04:33 PM   #3
vmals89
My Ride: e46 m3
I hope it's the famous m clunk but it is happening very often. There is also the famous M subframe crack which can cost 2k to fix. (God I hope not lol)
http://forum.e46fanatics.com/showthr...t=subframe+diy
The video in this dyi thread is what I think I am hearing.
Old 09-24-2012, 12:51 PM   #4
Horst
My Ride: 2003 M3
Bushings are pretty robust and would not causing a clunking sound. A severe crack or tear in the bodywork that the sub-frame attaches to will make noise. All things considered, sub-frame issue are very rare unless that car has a bunch of weight in the trunk (stereo equipment) or it was abused (burn outs, crappy roads, etc.)
Horst is offline   Reply With Quote
Old 09-24-2012, 01:04 PM   #5
ModBargains III
ModBargains III's Avatar
My Ride: E46
Yeah you'll want to get in there and physically check everything to see what the issues are. If it does end up being the bushings though, you'll know where to get them!
PowerFlex Urethane Suspension Bushings E46 Non-M/M3
I hope that helps! Let me know if there's anything else I can do for you.
Sean S. | Sean@ModBargains.com |(714) 582-3330 ext 8009
We Specialize In: BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts |
BMW Wheels In Stock | BMW Intake Experts
Hours
Check out our Blog for updates & discounts!
ModBargains III is offline   Reply With Quote
Old 09-24-2012, 02:44 PM   #6
Alan
Alan's Avatar
My Ride: 2006 M3
You cannot diagnose bushings by sound.
Put it up on a lift and inspect them.
Alan is offline   Reply With Quote
bushings, crack, subframe
