Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 09-23-2012, 12:03 AM   #1
Mike Larry
Mike Larry's Avatar
My Ride: 575 nello
Building a loft in a high-ceiling condo
I want to put a loft into a condo with high ceilings in order to make more space. I need ideas, but i'm not sure that i'm using the right terminology when i run google searches because there seems to be a ton of different meanings for "loft".
can someone point me in the right direction so i can get some ideas? TIA
Mike Larry is offline   Reply With Quote
Old 09-23-2012, 09:22 AM   #2
JTLaz
My Ride: 2010 Wrangler 4 Door
So you basically want to add a second level in the existing condo thy has stair access, etc? Is that what you mean?
The easiest way would be to probably anchor four steel poles into the concrete floor that hold up the loft.
JTLaz is offline   Reply With Quote
Old 09-23-2012, 09:37 AM   #3
Yassoon
My Ride: 325i
Try looking up 'mezzanine'
Yassoon is offline   Reply With Quote
Old 09-23-2012, 10:28 AM   #4
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
big money
chances are if it were feasible, it would already be there.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 09-23-2012, 10:29 AM   #5
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
Hire an engineer
Prob not worth the cash
JonJon is offline   Reply With Quote
Old 09-23-2012, 03:19 PM   #6
Mike Larry
Mike Larry's Avatar
My Ride: 575 nello
yes, that's exactly what i mean. i'm just looking for ideas in terms of layout (e.g. where to put the stairs, height of first level vs second level, etc.), so i really just wanna look at some pictures and designs of other people's homes/apts to get suggestions. i'm not looking for some sort of a diy because i'm definitely not building this on my own.
Old 09-24-2012, 09:35 PM   #7
casino is no lie
My Ride: M54B30
Do a search for "add second floor loft" and you might get some better ideas. Really depends on the situation I imagine and if you can even get a permit for construction to begin with.
casino is no lie is offline   Reply With Quote
Old 09-25-2012, 08:33 AM   #8
GlockMan
GlockMan's Avatar
50k minimum.
If it was a good idea, it would have been an option from the beginning.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 09-25-2012, 05:30 PM   #9
sea6speed
My Ride: 2010 335i Msport 6MT
Are you sure you own the areas it'll anchor to? Otherwise, you'll need to build it as a free standing structure.
sea6speed is offline   Reply With Quote
Old 09-25-2012, 05:42 PM   #10
SamDoe1
My Ride: 4cyl of fury
Also need to ensure the structure below will support the weight of what's above as you will be effectively doubling the load.
