///M3 Forum
Old 09-23-2012, 01:56 PM   #1
Xanthoxx
My Ride: 04 BMW 330CI
e46 M3 Limp Mode after Euro Headers
So I installed my euro headers this weekend with a new CRT from Custom Performance Innovations, 200 Cell Cats and EGT bung.
I was very careful to install the 02 sensors properly, the two side by side at rear of valve cover, A, the furtherst right is bank 1-3 precat, the other is 4-6 precat. The Post cat 02s on the side of the engine, along with the EGT were removed from the harnes and routed down the right side of engine. Everything is tucked away safe from heat.
I finally finished and anxiously fired it up, and to my dismay, rough idle. I restarted car 5 time to get the check engine codes.
No 02 errors........
1b69 Engine coolant temp
1b90 fuel control bank 1
1b91 fuel control bank 2
1bcd warmup misfire cyl 1
1bce warmup misfire cyl 2
1bcf warmup misfire cyl 3
1bd5 warmup misfire multiple cyl
This is all so far.......but it results in massive limp mode.
Any thoughts?
- Xanthoxx
Xanthoxx is offline   Reply With Quote
Old 09-23-2012, 06:16 PM   #2
HakenTT
My Ride: 323i with S54
you switched the 02 plugs. You plugged bank 1 into bank 2 and other way around.
HakenTT is offline   Reply With Quote
Old 09-23-2012, 06:20 PM   #3
Xanthoxx
I just pulled it all apart again to make sure... Plug A at rear right of valve cover, the far outside one closest to driver is bank one and it is in my long header, cyl 1-3. Additionally they can only be swapped at the header since the plugs are different on the car harness. But to ensure I unhooked and removed both, and ran "A" to the long header to ensure before hooking up the second.
The reason I say this is there is a 1 on the A harness (shown on black plastic, hard to see) on far right rear, that should correspond to bank 1.
Still limped.
- Xanthoxx
Old 09-23-2012, 09:38 PM   #4
Xanthoxx
Picture Wrong
Ok so I swapped my precat o2s and the car stayed out of limp mode while driving around the block.
Apparently the picture I used has the precats swapped but it is still odd that the wire marked 1 is for the short header rear bank cyl 4-6. dunno:
- Xanthoxx
Old 09-23-2012, 09:53 PM   #5
vonbimmer
My Ride: 01' E46 M3
I have a sensor diagram if you'd like a copy just shoot me a PM with your email. I had trouble sorting this out too, but dodged the limp mode.
vonbimmer is offline   Reply With Quote
