Sponsored by BimmerWorld
Old 09-23-2012, 04:05 PM   #1
ajai
My Ride: 330ci***65104; 328i
Will spacer decrease handling
Will spacer decrease the handling and stability of the car?
I add spacers before on my other e46. And the handling seems to be decrease.
the car feel week on corners.
Is this normal? Since I plan to get spacers for my other e46 .
but I want it to keep the handling.
missed the ci, welcome the i
ajai is offline   Reply With Quote
Old 09-26-2012, 02:33 PM   #2
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
What brand of spacers are you using? Do you have wheel studs or still running the factory wheel bolts?
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 09-26-2012, 04:24 PM   #3
trippmann
My Ride: E30
Send a message via AIM to trippmann
i believe it actually enhances the handling of the car due to the fact that it increases the with of the wheels from one side to the other.
I'm surprised along with "making 100k a year, and dating super models" this forum doesn't have "make my girl cum every time" to the list.
Originally Posted by Tampa02e46 View Post
^It seriously was the worst decision of my life to sign up for this site.
trippmann is offline   Reply With Quote
Old 09-26-2012, 08:13 PM   #4
ModBargains
ModBargains's Avatar
My Ride: M3
It should not affect your performance or decrease the handling unless maybe you were using some crazy large spacers. Check out the H&R Trak Spacers. These are track proven and TUV approved! If you want a bit better handling, you should add a H&R Sway Bar which will help to keep your car more planted and help to eliminate body roll.
H&R 3 Series Spacer Benefits:
  • Up to 70% lighter than competitor spacers
  • Improve appearance without buying new wheels
  • Improves handling by widening vehicle track
  • Anodized for tough and durable finish
  • Hub centric for accuracy and no vibrations
  • 100% made in Germany, AND TUV approved
  • ISO9001 approved
Blake Brunner|blake@ModBargains.com|(714) 582-3330 ext. 8011
We Specialize In:
BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts | BMW Tail Lights |
BMW Wheels | BMW Intake
Hours
Check out our Blog for updates!
ModBargains is offline   Reply With Quote
Old 09-26-2012, 08:41 PM   #5
e46JAB
My Ride: 2000 323CI, 2004 M3
This.
e46JAB is offline   Reply With Quote
Old 10-01-2012, 03:20 AM   #6
illestminimike
My Ride: Project Drama
I agree with modbargains on the H&R spacers. I have them. They are awesome.
Old 10-01-2012, 03:57 AM   #7
mkodama
mkodama's Avatar
Spacers have no noticeable effects on handling.
Old 10-01-2012, 07:47 AM   #8
JohnBlaze
My Ride: Black Sunshine
but they will lower the center of gravity ever so slightly, so in theory handling performance shoud increase.
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 10-01-2012, 07:51 AM   #9
SeanC
My Ride: 330i
Please explain how spacers will lower the center of gravity ever so slightly.
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
SeanC is offline   Reply With Quote
Old 10-01-2012, 04:55 PM   #10
mkodama
mkodama's Avatar
Not sure if joking or really stupid.
Old 10-01-2012, 05:23 PM   #11
scca_ziptie
Spacers will provide a small increase of stability in fast/long duration corners and will slightly decrease responsiveness in quick direction change (very small, to some not noticeable). It is primarily for looks, but does have a small effect on cornering behavior. Again, it is a small change.
Old 10-03-2012, 10:03 PM   #12
e46JAB
I was wondering the same thing...
Old 10-03-2012, 10:49 PM   #13
TerraPhantm
My Ride: M3 & ZHP
Should improve it. Since stability essentially comes down to having as low of a center of gravity as possible with as wide of a base as possible, widening the base should improve stability. The increased width is so small that the effect will not be noticeable in most cases.
Old 10-06-2012, 12:36 PM   #14
ajai
maybe when I last got spacers I have blown shocks. Therefore when I took off the spacers the handling seems better
Old 10-08-2012, 06:51 AM   #15
subieworx
My Ride: ZHP, 335, E53, E30
Spacers will increase track width, but not in a way that you want. Increasing track width for the purposes of handling should be done with longer arms. Using spacers can increase grip, but will have a detrimental affect on steering response due to the increase in scrub radius. This will lead to heavier steering that is not quite as precise and a car that will tram line quite a bit. The affects are magnified as the spacer gets wider.
subieworx is offline   Reply With Quote
