///M3 Forum
Old 09-23-2012, 10:27 PM   #1
rliberty
My Ride: Family Car
drivers window will not auto crack
I have tried everything...the auto down works. The auto up works sometimes. The window will not crack though when i open the door to then close when i close it. Any help would be awesome.
rliberty is offline   Reply With Quote
Old 09-23-2012, 10:39 PM   #2
Tchleung
My Ride: 02 M3
Reset the window memory.
With door closed, open the window all the way up, then once it's at the top, hold up on that switch fully for 5 seconds. Then click it to roll it all the way down, then press the switch this time and hold it for 5 seconds. See if that works for ya. Usually have to do this after a battery reset etc.
Follow me on Instagram @tommtomm84
03 Carbon Black X5 4.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
456whp/312wtq @ 8psi, No #'s yet at 9psi
4.10 / Headers / ESS VT2-550+
Tchleung is offline   Reply With Quote
Old 09-23-2012, 10:59 PM   #3
rliberty
My Ride: Family Car
Thanks for the input but i tried this....still didnt work. Any other solutions.
Old 09-23-2012, 11:55 PM   #4
choxor
My Ride: JDM
Does it ever roll back down a little after you roll it up? May be the pinch sensor.
Old 09-24-2012, 01:29 PM   #5
rliberty
My Ride: Family Car
No. It does not ever roll down after I roll it up...
I installed a hard top on the convertible and i would really like to get this fixed. It continues to affect the felt lining on the hard top.
Thanks for the suggestions. Looking forward to a solution.
Old 09-24-2012, 10:44 PM   #6
$ilent ///M
My Ride: 03.5 M3 smg lsb
How are you doing the reset... you need to hold the button up for bout 10 seconds then hold down (not one touch down) for another 10 seconds
$ilent ///M is offline   Reply With Quote
Old 09-25-2012, 12:46 AM   #7
choxor
My Ride: JDM
Ah, the fact that it was a vert would have been pertinent information.
Old 09-25-2012, 10:20 AM   #8
FLarrazabal
My Ride: 325Ci
I have a 325Ci with a few issues, it started with the close when door shut funtion of the front windows. Its the function the lowers the front windows approx 1/4" when you open the doors in order to clear the convertible weather seal. Upon closing the door the windows automatically raise to the full close position. I noticed that when the driver side door is opened, the the door open light on the instrument panel will not come on, the overhead light will not come on and the window will not lower. Also when I use the key remote to unlock the doors, the left door will not unlock, it will however lock with the remote. Everything works fine with the left door. I called the BMW dealer in town and they said it may be a loose wire or maybe it needed a computer reset. About $300.00. I've done some research and those functions are controled by the door lock itself. So I removed the door lock from the door which requires the removal of the airbag, window, and window regulator, a true pain since the window has a number of adjustments. I did not find any loose wires but the door lock did look worn out. I will be ordering a new one soon and hopefully that will fix the problems. After installing everthing back, I noticed that the airbag warning light on the instrument panel was on. I rechecked that the airbag was connected and it was. I did some research and found out that I could reset the computer and that would turn the light off, the maintenace manual also said that after an airbag change the computer may have the be reset. Ok so I find a video that shows how to reset the computer, however I think I've messed something up because now my convertible is acting up. Here is what its doing, I start the car and push the top down button, nothing happens, I lower the windows and then push the top down button again, not the top lowers normally. Now I try to put the top up but nothing happens with the windows up or down. I turn the car off and restart it back up, now the top up button and everything works fine. I tried cycling the the top again, but again same issues, top comes down normaly but have to shut car off then back on, then the top will come back up. Not sure what I have done, also when I tried to reset the computer when I turn the ignition switch to the first position I hear a switching noise comming from the area where the CVM (convertible top module) is located. This is all driving me crazy, I have found the CVM and convertible top manual, but no help there
FLarrazabal is offline   Reply With Quote
Old 09-26-2012, 01:33 AM   #9
808elise
My Ride: TURBO/WB E46 M3
I am having the same issues with window on passenger side and door lock on passenger side. My last one had the issue on the driver side. I plan on getting it fixed soon. Interested to hear how this all works out so I know what to do.
808elise is offline   Reply With Quote
Old 09-27-2012, 07:58 AM   #10
makecopies
My Ride: Gods Chariot
I have done this before. This works.
makecopies is offline   Reply With Quote
