Old 09-24-2012, 04:46 PM   #1
YOLO89
My Ride: Hooptie
Oil light
Whenever I start my car the orange oil light (I believe) stays on for about 2 minutes then goes away. Anyone experience this issue also? All filters and oil are new if that means anything.
YOLO89 is offline   Reply With Quote
Old 09-24-2012, 05:35 PM   #2
taburki1s
My Ride: 2003 BMW 330i
You need to replace your oil level sender next time you change oil.
taburki1s is offline   Reply With Quote
Old 09-24-2012, 05:48 PM   #3
YOLO89
My Ride: Hooptie
Ah I see. Is that an easy thing to do?
Old 09-24-2012, 06:13 PM   #4
smooth1
My Ride: BMW FTW
Common issue on E46. The sensor still works just fine (If you actually do end up having an issue), you just get the light at startup. Mine stays on for about 30 seconds. Best to replace if you get a chance.
smooth1 is offline   Reply With Quote
Old 09-24-2012, 07:59 PM   #5
Steven747
My Ride: 05 330ci
replace the sensor with oem sensor when doing your next oil change
