Old 09-24-2012, 05:30 PM   #1
Livinbau5
My Ride: 2003 BMW 330i
Whats wrong with my engine??
I switched my spark plugs a while ago and i put in the 1 prong iridium ones. I found out that they sold me the wrong ones so i bought the bosh 4 pronged ones.
A few weeks later i noticed that sometimes when my car is in idol it starts revving to 1500 rpm. A few weeks later the check engine light came on and ever since then every time i start up my car in the morning the engine starts shaking a little (misfire?).
I took it to the shop and it said system to lean and misfires in bank 1,2,3,4,5,6.
My mechanic suggested switching the o2 sensors and coils packs and seafoaming the engine and fuel lines. I did everything and nothing has changed. It has been 2 months and hasnt gotten worse but i need to fix.
Please help!!!
Bau5
Livinbau5 is offline   Reply With Quote
Old 09-24-2012, 05:31 PM   #2
jhaurimn
My Ride: 01' 330ci
What model / year is your car
PAST
2001 330ci - 117xxx (sold)
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
jhaurimn is offline   Reply With Quote
Old 09-24-2012, 05:33 PM   #3
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
Carry it to a BMW specialist not Firestone. Check for intake leaks first.
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 09-24-2012, 05:34 PM   #4
Livinbau5
2003 e46 330i zhp
Bau5
Old 09-24-2012, 05:41 PM   #5
jhaurimn
My Ride: 01' 330ci
You want 4 prong spark plugs. Ngk and Bosch are the two brands to use, but some people had problems with bosch. I didnt, but you should buy a set of 6 ngk laser platinum oem plugs. (4prong). Make sure they get torqued properly !!!!!!
Also the lean code means you got an intake leak. Check your intake boots first
PAST
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
Old 09-24-2012, 05:56 PM   #6
Livinbau5
Yeah the 2nd time i switched the plugs i got the 4 prongged bosh but i just called bmw and they said before they look at my car to change to ngk.
Bau5
Old 09-30-2012, 11:33 PM   #7
Beamer Creamer
My Ride: 2005 bmw m3
Ive only used the platinum ngk 4prong. Start by switching mechanics even if u are friends. Sounds like he could have cost you alot for nothing. Sounds like your o2 sensors are doing what they are supposed to. So many people just change o2 sensors when code comes up even though alot of the time it was just telling you that your engine wasnt burning properly. O2 sensor codes come on when they hit a signal range of too high or too low too many times. Agreed check intake first. Can spray carb cleaner around fittings, hoses,etc. and see if you hear rpms change.
Beamer Creamer is offline   Reply With Quote
Old 10-01-2012, 01:02 AM   #8
Livinbau5
Yeah i found the crack in my intake pipe. Im going to replace the piece tmr. As for the rpms yeah im switching the spark plugs to ngk. Thanks a lot guys. You saved me a lot more time and money and headaches
Bau5
