Why flare wrench needed to replace brake lines? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 12-28-2012, 12:15 PM   #1
Westrace
My Ride: 06 G35, 04 M3 Coupe
So I am looking to this and I am not sure why a flare wrench is needed. Seems like a regular wrench would do.
Mad Russian seems to suggest you need a flare wrench.
http://m3.madrussian.net/diy_front_brake_lines.shtml
Westrace is offline   Reply With Quote
Old 12-28-2012, 12:18 PM   #2
bmwporschefan
My Ride: 2001 330xi
Technically you can use a regular open end wrench but you risk rounding off the nut. A flare wrench is definitely the better tool for the job.
'01 330xi
bmwporschefan is offline   Reply With Quote
Old 12-28-2012, 12:19 PM   #3
330i SDJ
My Ride: '02&'97 M3, '71 2002
A 6 point flare wrench (11 and 14 mm IIRC) will grab those small fittings better. I won't say I've never used an open end on a flare or compression fitting, but its not as beefy as a regular hex nut so more prone to getting marred/rounded off.
330i SDJ is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-28-2012, 02:00 PM   #4
Westrace
I went to Pepboys and AutoZone but they only have 12mm/13mm then 15mm/17mm, for some reasons, nobody is carrying 14mm size flare wrench. That's why I asked. These flare wrenches are hard to find. Looks like one has to order online.
Old 12-28-2012, 02:03 PM   #5
Alex323Ci
My Ride: M3 & 323Ci (sold)
well like the two previous posts mentioned, the nut for the fitting is a softer alloy. so to grip all corners (so not round off the corners) you'd want a box end wrench. But since a box end would not allow you to remove after its tight(because it would have a brake line inside it). so there is a flared end wrench that has a slit in it large enough to allow the brake line to pass.
strip that fitting and you have to cut the line, get a new fitting and then flare the line (with a flare tool) to get it back. big hassle for stripping it
Old 12-28-2012, 02:18 PM   #6
jdstrickland
My Ride: '94 325iC & '00 323i
You need to go to a better store. Or more of them. I have a 14/16 flare wrench from GreatNeck. Not the best company, but I think I used it once about 10 years ago. It was part of a set that covers all sizes from 10 to 17 or 18.
Old 12-28-2012, 02:19 PM   #7
jdstrickland
Also, don't forget Sears.
Old 12-28-2012, 02:22 PM   #8
Jesse M
My Ride: 05' ZHP
I installed my stop tech ss lines, front and rear, with your run of the mill Craftsman open ended wrench. Worked perfectly and didn't come close to stripping. Just go easy and make sure the wrench is fully on the nut before you tighten it..
Jesse M is offline   Reply With Quote
Old 12-28-2012, 02:22 PM   #9
Zell
Zell's Avatar
My Ride: so turbo wow
I was wondering this as well. Never knew why but I knew it was important.
Turns out flare wrenches significantly decrease the odds of rounding out the bolt, and if you round out a brake line, that's a baaaad day.
Old 12-28-2012, 02:58 PM   #10
jdstrickland
The problem comes when the flare nut seizes in the fitting, and the flat wrench merely folds flare nut around the brake pipe. This destroys the flare nut, which requires the entire brake pipe to be replaced.
Use the proper wrench, you can never go wrong. Well, almost never.
Old 12-28-2012, 03:25 PM   #11
Stickbuilder
My Ride: Touring, and others
Find a Snap On truck and wait for the driver. They can hand you what you need. Mac tools and a couple of others come to mind too.
[/SIGPIC]I'm fluent in 3 languages:
English
Sarcasm
Profanity
Stickbuilder is offline   Reply With Quote
Old 12-28-2012, 07:52 PM   #12
bmwmp
My Ride: 99 328 i
you can also go to lowes or home depot but they are easily found as line wrenches, and they go all the way up to 19mm
bmwmp is offline   Reply With Quote
Old 12-28-2012, 08:32 PM   #13
7xWDC-MSC
My Ride: 2005 325xi
Use a flare wrench. 99% of open ended wrenches out there for the consumer are junk. i.e poor metallurgy, inconsistent and/or oversize tolerances.
7xWDC-MSC is offline   Reply With Quote
Old 12-30-2012, 01:52 AM   #14
Westrace
Just finished. I don't think you really need a flare wrench. Actually it might be a little easier with an open wrench. The flare wrench is meant to protect the nut on the brake line which is what you're replacing anyway so any damage wouldn't be an issue.
Anyway, had to do the old fashion manual bleed, which most people think might be risky. Lol's, hopefully I didn't blow the master cylinder.
Old 12-31-2012, 01:26 AM   #15
Cazz
My Ride: 2005 BMW M3
If you don't have a flare wrench, use a box end wrench to break the nut loose. You should be able to break it loose and close it again without hardly any fluid getting out. Then put your bleeder hose on and use an open end wrench.
The chance of stripping it should be lower with a box end, but you might drip a little brake fluid.
*Edit: NM. I thought we were talking about bleeding brakes. This is about removing the brake lines.
Cazz is offline   Reply With Quote
