///M3 Forum
Old 09-25-2012, 03:41 PM   #1
M3Newb
My Ride: E46 M3
VANOS System
I have been reading alot and it seems like there are a lot of people that have problems with thier VANOS systems with it going out (seals, etc.). What are the warning signs of this? Ive heard that it makes a rattling/ticking noise. My car is very noisy with my exhaust and I always ignored ticking sounds becasue the injector tick on my SRT4 was so loud. I threw a CEl and the car seemed to go into limp mode so i parked it and turned it off and then back on and it was fine. Then today I was sitting at the fast food window and my car just stalled out of nowhere. I also dont feel the pull very hard and ive heard you lose HP/TQ with vanos problems. Could these be related to the VANOS system? I have 117,000 miles and i dont think its ever been checked out. Does BMW offer any type of VANOS inspection?
Caliber SRT4 330WHP>2003 Terminator 510WHP>2000 Civic SI Turbo project fail 180HP> E46 M3. You live and you learn.
M3Newb is offline   Reply With Quote
Old 09-25-2012, 04:43 PM   #2
illestminimike
My Ride: Project Drama
Just do it.
http://www.beisansystems.com/procedu..._procedure.htm
Old 09-25-2012, 04:55 PM   #3
Firstboost
My Ride: 2006 Tiag ZCP
If your vanos sealing plate is leaking oil from the o-rings, you'll be able to tell by checking the top, front, left hand side of the motor right where the VANOS connects. Since the engine is angled, all the oil will trickle down there.
In regards to ticking, I just replaced my VANOS exhaust hub because I swore a louder ticking had started to occur, but after the fix, it's still there. I've noticed the S54 is just inherently noisy.
If you're that worried, just pull the valve cover off. The hardest part is moving the wiring harnesses around to pull the cover off and put back on.
Firstboost is offline   Reply With Quote
Old 09-27-2012, 06:26 PM   #4
theOSUbob
My Ride: LeMans Blue E46 M3
I am throwing VANOS codes, the dealership wants to replace the whole thing ($4Kish, yikes). I took it to a very reputable independent shop who took it apart, said everything "appears" to be in working order. They replaced a sensor, said it might fix it... and it did, for about 3 months, now I am throwing the same codes again. Independent shop says next step is the solenoid replacement. My only thing is I don't want to keep paying them to take it all apart and replace a piece on a hunch, just to have it fail again in a few months. I am probably going to bite the bullet and do the whole thing.
theOSUbob is offline   Reply With Quote
Old 09-27-2012, 09:57 PM   #5
Prdquik
My Ride: 04 M3 Coupe
I had same problem. Picked it up today from solenoid replacement. $1,200 bucks. Ouch!
Prdquik is offline   Reply With Quote
Old 09-28-2012, 07:11 AM   #6
M3Newb
My Ride: E46 M3
Im guessing if anything on the vanos system was faulty (seals, solenoids, pump, etc.) it would throw a code? SO unless i have any CEL's i shouldnt have to worry?
